These where my results. The cam gear is still set at 0 Degrees, and the champion god sydney Kid has some great ideas that will help me, because the cam gear at 4 degrees made the car lose power, a total of 30rwkw.
But as sydney kid said, the cam gear needs to be set at 4 degrees and the ignition timing on the CAS needs to be checked with a timing light.
Will pay him a little more to check it tomorrow.
**** the car is fast now.... Like really fast.
This is all at 11psi - here are my mods
Enclosed Pod Filter
Hybrid Intercooler
Stock Plenum
Stock Turbo, and unopened motor
Full split Dump and front pipe, 3 inch
High Flow Cat
3.5 inch cat back, small muffler and 4 inch cannon
Apexi Power FC with Hand Controler (Nengun July Special for $1149 delivered..)
**** it's got some balls now.
never dealt with them before, not mates rates but it cost -
$690, but they -
****ed around with the cam gear (with no results) still at 0 degrees (any movement lost nearly 30rwkw)
over 30 dyno runs, used over 12 tank!
New Timing Belt
Radiator removed and install twice (once to put the gear on, and once to put the cam cover back on)
Coolant Flush
2 days worth of tune
Guy stayed late working out the PFC
Showed me heaps about it
awesome result mate!!
was that with 98Ron?
nah, 95 ron fuel (all we got) and with a 8 - 10% mix of toluene
I am going to have to keep putting it in or it might ping the mechanic says.
Better for the car anyway
Interesting..I'll be doing the same, but with a exh cam gear and a GTT intercooler.. I had 139.7kw with just a pod..
I've bought the cam gear some time ago so I'll just put it on and see what happens.
great effort But i have an r33 series11,with blitz lm fmic,4inch exhaust apexi, no cat,powerfc, boost control kit,dump pipe from turbo apexi pod filter cold air box and mine produced 214.8rwkw with 15psi. :cheers:
just remember, I am only running 11psi, and I have a cat.
Anything over 14psi is flogging your sII turbo hard and don't expect it to last long.
Whats your detonation levels like?
managed to run a 13.6 down the quarter mile in Mackay here.
Hardcore lowered JIC Coilovers (disadvantage)
18" 235 Tyres (20psi)
And a dirty pod filter.
What do you guys think?
I reckon I could get more out of it :rofl:
