Hi all
I'm on the market for some form of boost controller, and i think i'm leaning towards an electronic one like a profec, or an AVCR etc.... i just want to know what ones people have used, your experiences with them etc, the pros and cons, as there seem to be a fair few out there, and i'm having a hard time deciding :confused:
If it helps, i'm aiming for around 180 - 200rwkw in a R32 GTS-t
https://www.sau.com.au/forums/topic/52310-experiences-with-ebcs/
I have only had experiance with the Profec B and would highly reccomend them. Not as many features as the AVCR but very good at what it's built for, stable boost control even at higher boost pressures eg 22 psi and very easy to use and the benefit of the optional switch on the steering wheel.
i have an AVCR and it is awesome! does not spike at all... a lot of people like the blitz and HKS units as well as the profec B... i think if you use one of those you are getting a good unit... depends on your budget i suppose...
    • yeah, there's a country that recently started importing Skylines, I blame them.
