PFC Boost Controller
Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
You can also remove the veins from the HICAS portion of your existing pump. -
By DatsunBanana · Posted
Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this. -
Cheers, yeah it was recently imported, is the actual Nissan not an Infiniti so will have to do some chasing around for parts. Any ideas if the side skirts from a Q50 would fit on the 400r?
I remember reading that there’s a power steering pump from a modern car—possibly a Mazda—that bolts directly onto an RB engine and lines up perfectly, making it a great option for HICAS removal. Unfortunately, I’ve forgotten which model it came from. Does anyone know what vehicle this pump is from? Any help would be appreciated.
