Hey Guys,
In prep. for the track day at Sandown next month I'm getting the brake fluid changed to a track ready spec so I don't boil it after a couple of laps :flamer:
For those of you (read: any Team Wang members :) )who have changed their brake fluid to a track ready type (higher boiling point) which readily available brake fluid would you recommend for a r33 gtst?? Just to note that the setup is std except for upgraded pads.
Also are there any compromises to using this fluid on the streets?
Thanks
ant95gtr.
https://www.sau.com.au/forums/topic/52320-which-brake-fluid-to-use/
  • Replies 40
I use the Castrol SRF. Its (apparently) the best - but will send you broke.
Most of the guys use the Motul Dot 5.1. The only adverse effect I know about high quality brake fluids is the lightening of the wallet effect. I stand to be corrected on this however.
Thanks for all the info guys.....had my car at calder a couple of weekends ago at a driver training session.....the comp. circuit isn't very long or hard on brakes but by the end of the day I had to stick my foot through the pedal in order to wash off any speed. Not the best feeling when hoofing ur car round a track ;) I figure that sandown is waaay harder on brakes so gotta get that fluid changed!
Yeh brake fluid is important, and i have no doubt that the Castrol stuff it top shelf, but i suspect most of use can make do with less.
I posted this before...
... i use AP Racing Formula DOT 5.1 Road/Competition Brake & Clutch Fluid. Part No. CP4510 , but may change to Motul RBF 600 whish i have heard good things about. Cheaper and still very effective is the Caltex GP 600 Racing Brake Fluid.
There are lots of guys running the Caltex up in Sydney as Race Brakes up there are now readily using it in all the street / track cars as they have been getting good results with it and it almost a third of the price of the AP stuff i use....from memory it cost $30 for 600ml .
Disregard above post....i need new fluid and pads before Sandown as well so just got some prices together.
The two parties i spoke to said dont bother with anyting other then Motul RBF600, which is $25 for 500ml. They are using in Stokell's Diablo and its working better then all the previous fluids. So good enough for me.
Also as far as pads go, (Prices are all form Race Brakes - Melb)
DS3000 are $385
Track only...save your road pads for the road and race pads for the track. They are actually easier on rotors with less grinsing when they are aup to temperature...so noise isnt the only reason not to use them on the street
DS2500 are $231
Road/track but as Snowman will tell you they aint exactly a great road pad.
RB74 are $160
What i have been using and have always been very happy with, Race Brakes still seem to think they will be up the job at Sandown given my cars weight power and tyres.
As my RB74s have about another 6-9 months of normal driving in them, im leaning towards the DS3000s (or the SAUWA - Hawks) for the track, since ill be changing wheels its only an extra 5 min per corner.
I am going to tack onto this thread and add...
Just got back from picking the car up from Meridian, top stuff in spending like 7 hours fitting the oil cooler to my beast!
I was initially going to get a set of Endless CC-R ceramic pads, but brent from nengun can't seem to source / get the parts... so... time is running out and I need to sort out my brakes.
Was talking to Toby at Meridian, and he was considering organising a group buy on braided lines (though prob not before Sandown).
Also, he uses an ATE brake fluid, one litre for like 50 bucks.
As for pads... thinking the RB74s might get a guernsey as a stop gap before I get these Endless pads. Does anyone think it is worth doing the DS2500s?
I have just fitted a set of ADR approved braided brake and clutch lines. I purchased these for $420 (brakes: front and rear) and $70 (clutch). The brakes are a two piece hose with a block in the middle, just like the originals, and bolt up in the original fittings. I have not yet felt the brakes as the car is still at the w/shop.
MALTECH: Brake Hoses & Cables
0418 378 939
(03) 5253 1931
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
