For Sale
1. Xtr 500hp Turbo
2. Power Fc And Hand Controller Plus Ext Lead
3. Injector Rail With 6 Apexi 555cc Installed
4. Z32 Air Flow Meter With Plug And Pod Filter
5. Surge Tank With Fittings Plus Bosch Fuel Pump
All This Was Installed On My R33 4 Months Ago Car Was Producing 282kw
Rw
REASON FOR SELLING CAR WRIITEN OFF
SELL AS ONE UNIT IF POSSIBLE PRICE $4500 ONO
MOBILE 0422396325
https://www.sau.com.au/forums/topic/52348-r33-parts-for-sale/
PLEASE CALL ME ON MOBILE TO DISCUSS
I live in Sth East Melbourne but am currently in Japan so thats an expensive ask, do you reckon you can help my out by PM or emailing me the info.
I can transfer the money to someone local for pickup if we work something out.
Thanks
