Has anyone replaced one of these, easy/hard. From the looks of things its not so easy. Will I need to remove the dump pipe. How much play is in the exhaust. CAn I unbolt it and then slide it off with the exhaust still attctched to the turbo??
Also found out that my turbo is not a HKS2510 but a HKS2535. hmm maybe time for some new injectors and push the boost up. Thats one good thing to come from this I spose.
https://www.sau.com.au/forums/topic/52351-blown-exhaust-turbo-gasket/
already got one, plus a monster bosh fuel pump, the thing sounds like a swarm of bees in the boot. I really need to get on the dyno and see I spose. Am getting some cam gears soon so will get those on and run it and see from there if its worth getting it chipped again (been done in japan). Its chewing some feul at the moment, leaving lots of carbon build up on the rear bar so I know its running rich.
Have got a GTR intercooler, oil cooler, 3in from the turbo. As for rwkw I dont know havent run it yet. I would be guessing around the 200rwkw at around the 1.15 bar as a guess. had a run with a WRX the other night he had front mount and exhaust etc and beat him so has some ponies.
what do you recon I can get from the turbo 1.3 - 1.4 bar if I have the thing remapped. I will get a better indication after I put the cam gears on and then run it.
What sort of power should I get from a 2535 on an RB20???
220 -240 rwkw very doable
check th ecolour of your injectors if they are yellow/gold they are gtr injecotrs chances are its been tuned for higher boost take the car to a good workl shop to do the dyno run . 1.4 bar should be doable but i wouldnt run that all day
meggala
sounds like a nice car
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
