mr180,
I just checked the Commander manual and it does say that the exhaust temp check light is used when there is a faulty sensor, however it goes on to say you have to use the commander to find out which sensor is faulty and replace it.... Not sure what is causing the commander to freeze on the Logo, is it brand new or second hand? Have you made sure the harness is nice and tightly plugged in??
Brett
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81598
Not sure if this is right or not, but I have heard that when you connect the PFC for the first time you have to deselect the boost control option if you are not running the boost controller or you get sensor errors as the PFC cannot find it (boost controller). If you do not have the boost control package, please disregard this post
Hope it helps
Steve
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81626
EVL R33,
Could you post that PDF file to tlee32@csc.com.au thanks.
The PowerFC I'm getting probably hasn't been used in a while, so that's why I'm thinking it could default back to the factory setting now. But I'll have to wait and see. Thanks anyway mate.
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81635
EVL R33,
It's second hand. Its plugged in tightly. The car starts up ok and idles... I dont think its the boost controller causing the problem as if it was it wouldnt start at all and I could at least turn the boost controller option off by using the hand controller.
Could it be the wrong commander?
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81656
Guest KILLER-T
Were the 3 commanders all off Nissan's? The info I have says that all Nissan power fc commanders apart from the r34 gtt are the same.
That can't be rite because Chris had a r33 gtst with a power fc He sold it and got a r34 gtt and used the same commander for it .
Sofar i have worked out that the commanders are not all compatable the older power fc's can only use the older ver commanders but the newer ver power fc's can use old or new commanders:eek1:
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81871
Originally posted by mr180
I just plugged my power fc in and it's stuck on the apexi logo... has anyone had this happen before? The exhaust temp signal is coming up, and the manual says that means one of the cars sensors isnt working, so maybe that's the problem? How do I get it working!?
You mean that the Apexi logo stay there? well, wrong commander for you..I have same thing happen before..
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-81901
Silver, PDF is on its way... It won't reset itself, it uses ROM to store the settings so even with the power off for ages it should still keep the tuned settings. Reset it as soon as you plug it in just to be safe..
mr180, it does sound like you have the wrong commander. Nengun sells them second hand pretty cheap so it might be worth while picking one up, that way you never have to run around looking to borrow one...
Also you do have to turn the boost control off if you aren't using the PFC Boost controller, but that's simple once the commander is working...
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-82203
Thanks for your help!
Ok, so I guess I have a new controller and an old pfc... I still need to get a commander that works to see if the pfc is ok. If it's the wrong pfc then I will get a new one off Nengun. I'm getting another commander to try this week, so I will just have to wait and see if that one works!:D
https://www.sau.com.au/forums/topic/5236-power-fc-questions/#findComment-82305
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
