These guys aren't stupid, they've worked in the auto industry for many years and usually know exactly what they're looking at.
its pretty funny that you say that, cause the guy that engineered my car had no idea about my turbo. the compliance guys convinced him that it was just the stock turbo on a different manifold. he must have been stupid cause he believed him and signed it off.
Vic Roads wasnt a problem either. The guy actually put his hand on the turbo when he was looking for the egine number. :rolleyes:
the only tricky thing is RWC...
There are a lot of people that don't know their stuff, but then you will run into those that do. It only takes somebody that *does* along the way and you're in trouble. And things only get stricter each year. Seems to me you have about three options:
a) take it to another state and try and transfer the rego (two lots of rego, etc) and see if the engineers can be still valid.
B) remove the turbo and return it mostly to stock (probably best option).. although soon as you change it back the engineers is invalid, so is any insurance (including if you hit a person on the road), and you only have to get pulled over by a nice policeman in vic and you're back where you started.
c) pay off the right people ..
You don't have much other options to totally frank. VIC is *strict* - damn strict.. .on most things. Just remember when it comes to insurance the story will be exactly the same.
Fark that...
RWC and engineering certificate will all be done in VIC. I have seen a few T78 big single modded R32's on the roads in VIC. It is possible and it will be done! I now have a few good options and I'm going to keep the keyboard quiet untill it's done. VIC is strict and even more so since unfortunate crash yesterday... heard that all cops were sent memo to book all "imports" with P plates (which will mean all imports get anal probes for the next month or so P's or not)
there are a lot of illegitimate cars in melb.. many shouldn't be on the road according to any applicable law - but they are.. see point c) :)
also see point B) - if you get an EPA (very likely seeing as just about every VIC skyline owner has had one.. inc me when i was there).. and you will have to remove that turbo.. no two ways about it. And the EPA are the clueist people I have ever seen inspect a car - I guess if you see a few hundred skylines you tend to know what a completely stock one looks like.
Fark that...
Does anyone know of a decent but reasonably priced compliance workshop in melbourne? I have a GTR coming with 2xGT2530's.. One workshop wants over $1500 to compliance the car, which i cant help but feel is a bit expensive,
Any help would be greatly appreciated :)
-Patrick
-Patrick
I only know of 2 and would recomend 1 - PM sent.
you safest to conver to tiwins for reg and engineering I always try to comly and reg my cars as stock as possible and they tend to go through quickly . my record for compliance and sign off is 2 1/2 days on the rb25 cef rwc was easy with it as well. if you want to play wit the big boys ie t78 you need to pay
cheers
Basically you are registering the car if it were new, so it would have to comply with ADR of the day. In other words your car would have to be a stock GTR R32.
If they wanted they could nknock you back for steering wheel, gear knob etc, etc ,etc.
Trying to legally get a T78 engineered and approved was a bit of an ask, when most people keep egtting defected for having a BOV.
If they can engineer and register turbo conversions in dattos, I don't see how a big single on a TT RB26 in a GTR is a problem.
Couple of differences:
- the emissions regs on older cars (eg datsun 1600's) are nowhere near as strict as on cars like GTR's
- engineering a turbo conversion requires a lot more work on the engineers part than an inspection to meet 15yo requirements. For example a full brake test would be mandatory (brake performance/fade, etc). In this case I've got no doubt the engineer has seen the single turbo, realised the car is not standard to a greater extent than he would otherwise accept, and decided he'd rather not take the risk.
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
