hay guys my mates car is in the mag street commodores issue 40 and is despretly in need of this mag so if you have any info of this mag or where i can get it from pm me with any info or ph 0421 830 517
https://www.sau.com.au/forums/topic/52410-any-one-got-this-mag/
Is it an old mag or new, what was on the cover or what were your interested in an article on a car, I have a shit tin of them, used to own a calais turbo.
hay guys cant say whats on the frount but i know its issue 40 with a purple calias with a full areo body kit and interor so if got any info on the one please ring me or pm me
How you going champ. the mag has a yellow vl and a red vr ss a chic in black and 'hell racer' on the cover. i am after a copy as my mate has a car in there and needs to get his hands on it. would be exellant if you could help us out. cheers
Got it dude, sent you a text...............happy to post it out. :rave:
