  • Replies 43
aaaaaaaaaahahahhah they just locked it
Us =1
Them = BIG FAT ZERO!
and inark, i'm sure you must be terribly distraught after being banned...
I'm sure we can organise some personal counselling for you in your time of sorrow.  :D
if u could set that up i would be greatful... i am very hurt about this.
The funny thing is I don't actually know of anyone who owns a GTR thats in IT!
Manufacturing
Publishing
Accountant
Pizza Shop Owner
Dentist
Engineers
Mechanics
Tow Truck Driver
I could be wrong - I may know someone from here that owns a GTR thats in IT and don't realise it - but those who I know what they do aren't in IT! lol
Can add this to your list - I'm a purchase officer + I fang a forklift around the warehouse every now and then (work for an IT company... but I have NO IT skills at all...ironic) BTW it's also the largest IT co. in southern hemisphere. more ironic... so does this put me in IT? No offence, but I hope not.
Imports wrecking the modifying car scene? Ok, the following are imported...
BMW
Mercedes
Audi
Maserati
Porsche
Volvo
Nissan
Ferrari
Jaguar
Honda
Ford (some models)
Kia
Hyundai
Mitsubishi (some models)
Daewoo
Suzuki
Volkswagen
Saab
Subaru
Holdens (some models)
hmmm... that's A LOT of cars wrecking the modified car scene ;)
Dentist
You talking about me or someone else?
I'm a moderator with MCCR, but this got way out of hand before I even saw it. Please don't classify me as one of the MCCR dickheads - I've been a member of the club since before it became huge, and simply use the forums and lesser populated "cruises". I can't see myself attending any "open" cruises, and haven't for years...
I'm proud to be in IT.
I worked hard to own my GTR, and I make sure I drive it hard enough to use every inch of it's "supercar" soul. I bough the car because I firgued it would be the best all round car I could buy in my price range. (Which this was above)
Also who says a GTR can't drift? I'd like to take on that challenge!
I do all my own servicing and install my own mods, until tools I dont have are required.
Nothing more needs to be said about the mentality of the MCCR boys. One attendance to a cruize will say it all.
    • With stone chips, you really can't just try to fill them. You really have to sand that spot to lower the edges of the chip, so that the filler will end up covering a wider patch than just the chip. Otherwise, you're trying to have a sharp edged paint surface match up to some filler, and they just do not sand the same and you always end up with a noticable transition. A bunch of adjacent chips should be well sanded back, to round off all those edges, and use a lot (in a relative sense) of filler to raise the whole area back.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
