How much are you paying for CTP Greenslip
Here's a comparison on my 'new' daily (that I picked up 2 weekes ago) - registration due to-day.
It's just a '97 Maxima GV
As I said earlier, Shannons gave me a CTP Green Slip for $440
The existing final 2 weeks of rego was piggy-backed by NRMA CTP.
My NRMA Renewal CTP costs $742 for the same car & personal particulars.
Q. The difference?
A. $302
I'll tell you why Terri,
NRMA are basing their prices on the highest CTP risk and sending them out. Thus hoping for any idiot to pay it.
If you actually call them to discuss the particulars of the CTP for your situation it most of the time comes down.
tried this, they wouldnt budge.
could have been the person I was speaking to though.
Depends it's really only NRMA who was doing it.
You're situation is different Luke yours will most likely be around the 600-700 mark
Wait hang on
I rang today and asked the Q again re: getting it in APR not Livo
Got told it was $264 for 12 months???? Waiting for the paperwork to confirm. Awesome if that's the case (considering it gets driven like 6 times a year)
I think you'll find that's 6 months my dear. :P
Female Driver Age 41.
1 Point lost on her license.
Car (all of them) garaged in 2767.
Youngest Driver - 21yr old
No accidents.
1996 R33 Gtst - $787
1996 Honda EK Civic - $787
1995 Toyota AE111 (Personal Import) - $788
I hate this time of the year!
* Female Driver aged 41 with 1 pt lost doesn't count against you.
* Living at 2767 shouldn't work against you, except that you're still in the Sydney basin.
* Youngest driver 21 is your 'ball n chain' = my 2c
He/she isn't attached to all 3 cars huh?
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
