How much are you paying for CTP Greenslip
Is it registered under your parents address? If not then the RMS won't accept the ctp.
Wollongong is still classed as rural Lane cove is not.
Everything I have with RMS is registered under my parents address.
And yeah, I understand Wollongong is still rural, much less dense than Lane Cove
  • 1 month later...
Absolute bullshit. No accidents at fault, no demerit points and my CTP has gone up again this year. What a load of BS. I even changed the post codes around put a north sydney post code and a new model car. Seems the only affecting factor now is age and I could have sworn when you pass the age of 25 your costs were meant to drop. Gonna cost more than 1k this year just to get on the road.
Does anyone know of any other comprehensive car companies apart from Just Car who will do my R33?
Edited by SargeRX8
CTP is 29+
Yes insurance there is a drop when you turn 25 but you still aren't the best risk.
23 year old male r34 gtt in Sydney $420 with AAMI, you just gotta find the loophole, and it's legal too and it will cost you no matter what :-D.
Elaborate in a pm please. The only way I have found to get 300 off is if I change ownership of the car into my mums name.
  • 1 month later...
Paid $550 with NRMA last year and they wanted $767 this year.
Just paid $563 with AAMI.
HOW???
I just paid $764 for the Accord, the Fridge is up next soon too. I'm 29, never been in a smash... or have gained any demerit points in the past 5+ years.
Last year NRMA was under $560, this year I can't find a damn thing under $764.
HOW???
I'm guessing age (I'm 33) but all of them wanted over $750 except AAMI.
damn! please explain HOW?!
I just paid $767 with AAMI, what is this loophole for paying <$500
I'm 23 male, also haven't been in any accident in the past 5 years. Would love to know. PM me details? lol
  • 1 year later...
Thread bump rather than start a new.
Is it just me or is assuming there should be some competitive pricing between different CTP?
Twice in the last few months now I've obtained a quote from Shannons who my other car insurance is with for a quote as I'm currently with GIO.
Both times they came back exactly the same. To the cent!
Am I missing something? Is shannons just GIO in disguise?
Being a bit older and being a good driver for 35 years, or not getting caught, does help. sorry people but my ctp with shannons is $362. Skyline is in garage at night. Also comprehensive with shannons and have no claim bonus for life. it all helps in getting a cheaper rate including no speeding fines or at fault accidents.It also has a lot to do with where you live.
Edited by evil 33
nope, that's pretty much right.
And if you call around, they can't budget on price at all.
Told one the other was doing cheaper, got the response "oh well, we can't change the price".
So, I went with the cheaper place(by $5 from memory).
Yeah I got a bunch of quotes today and they're all within $15 of each other.
Kind of suspicious they all use the same online quote forms... maybe ACA can get to the bottom of this colluding conspiracy...
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
