How much are you paying for CTP Greenslip
I'm about to get some quotes for my 180.. last time I checked, I f**ked with every variable on the online quote app
I could be 30 and a bunch of accidents in my history, with like 1 demerit point left before suspension and the price was in the 600s.
But age 29 with perfect fkn record (which I somehow have) and its nearly $900
f**ks sake.
The writing has been on the wall since...
* insurance companies could collude with one another
* fake accidents in SW Sydney have led to fake injuries
* doctors 'in the know' don't 'rat' on their own kind
Compared to other states, NSW is the pits.
Not if your residence in Melb. But technically you can't have another state plate for more than 90days in nsw. As long as you make a trip to vic and back. Once in the 90 days and have a residential address in Vic. You should be fine. If it's in your sis name. All good.
I've been wanting these custom plates since I was a kid.... but I just can't justify giving the rta 440 a year.... it's not that I don't have the money.... just don't like being robbed.... fair enough if the money went to the right places etc and we had nice roads that don't ruin our cars etc...
  • Like 1
And they would know this how
  • Like 1
agree, talked to some of the QLD blokes, they can also own the plates..they were complaining the highest cost plates were 5k.
I relayed ours were 440 a year, so if owned for any more than 20 years, would already be over 5k.
Yes it was; and you're dead right.
They hope you're a complete imbecile and will just pony up the cash.
We got it sorted; but there's been a big jump in price in the last month or so.
QBE were cheapest with $593; which is a tonne better than NRMA's $756
I went with QBE this year, it was the best I could find at the time :)
  • 5 months later...
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
