How much are you paying for CTP Greenslip
13 hours ago, Hadouken said:
Lol. Sure I'll move to Sydney NOT.
Think about all the gearboxes I can buy with all these savings lol
That's a very big point you left out LOL
For some reason, it's double in Sydney. And I used to complain when CTP hit $500. I'm pretty sure I was paying $300-odd when I first got the GT-R.
I'll dig through some paperwork and make a graph.
way over 25, country/rural area, QBE $443.  Not bad rort, I've never claimed and am unlikely to so they will get +$20K out of me and I have three registered, so +$60k for my driving life.
All for some con artist to stage an accident with his uncle and claim $5 million for a sprained toe!!!
  • 4 weeks later...
My rego's due soon so I thought I'd check prices. Evo 6, Sydney north, max NCB, only couple of points gone. I just turned 30.
My quote last time was $900 - as mentioned they don't seem to adjust for driving record at all, the only variable yielding a discount for me was age. And now that I'm 30 I pay $150 less. It would be the same price even if I was barely hanging on with no comp and 1 point left on license. Madness.
AAMI $760.92 $389.72 more information 132 244 www.aami.com.au
Allianz $890.00 $455.00 more information 1300 137 664 www.allianz.com.au
CIC-Allianz $886.00 $454.00 more information 1300 360 340
GIO $754.04 $386.32 more information 131 010 www.gio.com.au
NRMA $898.96 $459.63 more information 132 132 www.nrma.com.au
QBE $890.00 $455.00 more information 133 723 greenslip.qbe.com
Edited by Skepticism
  • Like 1
  • 6 months later...
On ‎9‎/‎10‎/‎2017 at 8:01 AM, l0ckym said:
$456 GIO
R33 GTR
Living in the country
I just did an online quote with GIO, got it down to $603 (NSW). I'm going to call AAMI and hustle them.
  • 3 months later...
  • 3 weeks later...
  • 1 year later...
On 3/7/2019 at 11:50 AM, niZmO_Man said:
One year later, $507 (called up NRMA, they added VVC insurance and got a little discount)
Yep, my GTR this year in NSW was just under $500 which is a third of what I have paid for the last 15+ years. Is it aged based or have they just stopped ripping people off?
15 minutes ago, niZmO_Man said:
I think once it hit $800 people got the shits, NSW government had to sell the insurance companies to stop ripping us off.
Reverse economics V's Australian utilities (roads, power etc) ? Or will prices creep back up until they are 3 times now that it's privatised?
Hahaha crap, typo, s/sell/tell
Obviously the insurance companies are private. I should proof read. But yeah, it just kept increasing every year and they claimed (geddit?) it was the increased claims. Yeah right south-west Sydney isn't that dodgy.
Nope.
Still paying exorbitant amounts for mine.
  • Like 1
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
