I am after instructions for the Blitz Dual-SBC as one came in tha Stagea but no instructions.
Links to a site that might have them of a scanned copy would be great.
Any help is appreciated.
Hey,
Try this link http://www.team3s.com/FAQdsbcmanual.htm is that similar to the one you got?
Ive got an english manual though its for the blitz sdc i-d
Google is your friend :cooldance
