Had a little bit of a dissappointing result at the SAU:SA Dyno day today the M35 only pulled 126 KW :happy: It was on a mainline dyno, which they say under reads - but even so, would've liked a few more numbers. At least Ive got a baseline for future comparisons though.
i thought m35's ran 12psi stock?
you didn't even make it to 10
if its highflowed, its good to about 20psi but 14 will be safe with the stock ecu/boost cut
that is nuts Scott.
That would be a real handful in the wet.
Its quite docile actually, only spins up inside wheels in first, I would be stepping out sideways if it had an lsd though.
Of course I dont drive like Craig either. :geek:
I have the Nismo in my car at the moment and it comes on very strong in the lower rpm and in the Wet + 1st gear + a bit of fun = a very sideways car out of round abouts.....lol
Of course I dont drive like Craig either. :)
Oh you will....once you find the love of the LSD and loose the single spinner!!! :P
LOL....at least you can get sideway's at low speeds....I have to wait until I hit 60-70km's!!....lol
just love the way it stay's at about 1000nm's.......nice steady curve up to 300AWKW's as well.
Try that with a RB tractor motor :P
you realise thats tractive torque and the only way to measure engine torque accurately is on an engine dyno? so its not really 1000Nm
still an impressive result, should be even better if you guys get your ecu re-mapper sorted
Yep, tractive effort, and 200nm more than the 2j manual supra that was tuned before mine.
V6 FTW... :P
I have given up on the remap, mainly because I will be changing to the VQ35 soon. It looks like I am going down the Haltech platnum pro path.
Awesome result man... especially for a car so well behaved. (Yes I'm jealous)
Maybe you need to get it in an engine dyno to see exactly what nm it is pushing?
Edited by iamhe77
Probably easier to just get an RB powered car of similar output on the same dyno for a comparison.
would be a lot easier
but i think the tractive torque is affected by gear ratios, tyre size and a few other things so it may not be an accurate comparison
I think as long as the speed to revs ratio is the same it wont matter. Different gears, diff ratios and tyre sizes will change everything, not to mention auto box and awd etc.
if only i had the front hubs... we would know in 5 mins.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
