I've got a 1998 RS260 so the RB26DETT from a R33 GTR.
Put it on the dyno last weekend and it only pulled 110kws with 4psi boost?
I've just brought a power fc from japan and looking to get a Turbosmart E boost street.
What could be to problem before I put the parts on and tuned.
I would think it should have more power than that standard.
Thanks
Nick
Thanks
Nick
I dont know much but Id say the 4psi of boost will be part of the problem, for sure. What were the AFRs? Could be running very rich too.
Well thats what i think. I cant understand why its running 4psi. It should be waste gate pressure.
I'm hoping to be over 200kwsatw once tuned and 10-14 psi on the standard turbos.
Anyone know what the R33 gtr turbos will run?
Nick
I think 10psi is standard. 14psi is about the max you want to run safely. I'm running 13psi on my 260RS and have 200kwatw. Perhaps you have a blocked cat or a boost leak or something like that. 4psi is less than actuator pressure I think.
Impul ecu run just happened, much better than last time.. 173.5kw on the same dyno (we made a whopping 126 last time), and a stack more torque too! :D
A bit rich but more than liveable Dunc, I wonder if it is just running out of injector at max revs... :dry:
Knew there was something else I was meant to ask about :D next time.
What'd reckon my target AFR's should be? I'd assume at this point the only way to get it better leaner (aside from waiting for the Impul to self tune) is either emanage or an AFC?
Knew there was something else I was meant to ask about :dry: next time.
Yep, dont bother with the AFC, Emanage is very good at what it does and will allow multiple maps (e85 hint hint) and self tuning with a wideband.
You should be aiming for flat 12afr at full throttle, right through the revs. You are safer than that so theres no issue (other than fuel consumption) but if you notice it leans back out to 12 at the end, im just not sure what caused it. The injectors should be good for over 220. Perhaps its the pump but I would say its just a weird tune. Looks like you picked up a good one there. :D
Nice result Dunc.
Stock boost on your car is 12psi.. If you did the bypass on the boost solenoid you can have unlimited boost.
I think Craig has seen 24psi using my Impul ECU at the moment as there is no boost cut on this ECU.
Cheers
Andy
Hrm weird, I did do the bypass. Manifold pressure graph looks like it maxed out at 15psi though :dry: last time I maxed out at less than 10 pounds though.
Edited by Dunc
May have something to do with the exhaust? I know that Craig has 3" from the turbo back, so less restriction.
Can't remember what you have Dunc (is it just the group buy dump and stock exhaust?)
ah good point. At the moment Ive got a stock dump, with a 2nd cat in the pipes, and a nismo adjustable exhaust muffler (which was set to sport for the run). Might need to give that new group buy dump some consideration.
Edited by Dunc
Even if you don't touch the rest of your exhaust, change the dump pipe.
Certainly the biggest power boost when you do this. There is a massive cat in the middle of the stock dump that is soo restrictive.
On my car with the stock turbo I have seen 20psi when I did the bypass. Not for long as I don't thing the ceramic turbine will be happy for long even with a ball bearing core.
Cat in the stock dump is too restrictive?
Oh, you must be referring to this then :)
Yes Dunc. Change your sump pipe ASAP!
Either get in on the group buy unit or preferrably, talk to Scotty about one of his dump/front pipe units :happy:
+ 1 million! :happy:
I can vouch for the difference it makes even with a standard exhaust. Spools up faster, accelerates harder, more responsive, nicer engine note, slightly better fuel economy, need any more reasons? :)
  • Splitfire Coil Packs
  • FMIC 11psi
  • SAFC II
  • 2.5" Gutted Cat
  • Same as above plus
  • 3" Front Dump pipe
  • SITC
  • 3, 1/4" Cat back
  • Reinforced intake pipe
  • Boxed pod with CAI
  • Grounding kit
  • 3" Highflow cat
  • MV Auto's stage 2 shift kit
  • R32 GTR 5 Speed, HD fly wheel and clutch
  • Denso Hi-flow fuel pump (stocker wasnt keeping up while being tuned today)
  • 12psi allthough it has to be pulled out towards the top so it doesnt hit boost cut :-(
Not sure where to from here.... Im at the end of the road AFM and turbo, tapping boost cut every so often.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
