Stagea Dyno Results
where can i go for a cheap dyno run??? pref AWD, i remember back on the VW forums, when we had meetings the dyno days were 50 bucks, lunch etc all included. but that was a dyno day, i just want a dyno run.
anyone in sydney?
all runs in RWD >_<
Thats a good result from a stock turbo. More kw from now on start to get (more) expensive. Its good to try to work out your ultimate goal to save doing things twice. If you start going on the track/drags the tendency is to want more and more power without end! But for a road car 240kw is a fast car and 260 - 280 really fast.
If you figure that your turbo is going to blow one day then a rebuilt hybrid will get you up to say 220 on its own or 230 - 240 with bigger injectors and a Z32 afm.
If you want 260+ kw then I would seriously consider getting a Link or Vipec - then you can sell your SITC and SAFC and won't need a new afm or better boost controller. But you will need say a GT3076 or Hypergear turbo and bigger injectors and (depending on what you have now) a better fmic. And of course a top tune.
I finally got around to checking my car. Completely empty. hmmmmmmmmm
Do i have a leg to stand on at all with the company i brought the car off.
I'm suppost to be the first Aus owner and arnt they suppost to replace the cat upon compliancing?
What could be the next step in look at why its running 4psi?
I check the piping which comes from a metal pipe that runs around the back on the engine.
Then it splits into 2 and goes to each turbo!!!!!!
had car retuned to after some further mod's
current mod's
nismo fuel pump
nismo FPR
nismo 740cc inj
Z32 AFM
R34 PFC (c/o hills motorsport)
Greddy ProfectB spec II
Greddy inlet manifold
80mm hypertune throttle body
FMIC
Tomei Pon Cams
HKS 3037 kit inc high mount manifold and 50mm external gate
HKS 3" exhaust from turbo back
Manual conversion inc OS Twin Plate
final power figure 387hp at all four wheels on 1.3bar
A HUGE thanks to Sean and the guys at ALLSTAR GARAGE in Malaga WA
current mod's
nismo fuel pump
nismo FPR
nismo 740cc inj
Z32 AFM
FMIC
Tomei Pon Cams
Over 290awkw - should be a flyer! Any plans for a 1/4mile time?
have never run it down the 1/4 mile since ive had the car but im sure i will once the street drag series starts again in WA. would hope to see a low 12 on streets.
  • 3 weeks later...
Had the PNM35 on a 4wd dyno today. Absolutely stock, std filters exhaust, etc etc. Running a VQ35de. Dyno'd at 147.3kw- dynodynamics.
Flat Torque curve, running quite rich in the top end at 11.5:1 AFR
Pretty much as expected, V35's are running a little more, but you take into account auto-slushbox and 4WD loss to make up the difference!
I know, I know!!! Its being processed by the Minister for Finance and War...
Also that was on 95 pump, don't ask, the Mrs filled it up. :(
I had a chat to the guy, he said the biggest improvement he has seen on a V35 is a shot of NOS.... cue Fast and Furious moment... I couldn't believe it. But he said about 100kwatw and no engine damage :)
Prob won't be going back there for any work!
Edited by PN-Mad
I think nitrous is one of those things people are scared of.
Im not an expert by any means, but if you know what you are doing it is a very safe and cheap way to make good power at a very low cost.
Otherwise I can recommend some really nice twin turbo kits for you :( DO IT!!!
I guess thats the key... the consequences if you don't know what your doing are... not so good!
by the way... bbenny, I want your wheels. They are bloody awesome. Apparently they are no longer imported into Aus in that size by Avanti. I have an epic price on RPF1's in that size, but i don't think they suit. thoughts?
Yeah I was lucky enough to pick those up overseas at a steal! I was considering RPF1's they are much more understated, but look so tough!
With the RPF1's you have to get at least 9.5 wide of they have a really flat face - they need pull to look any good. Which is tough because the only one suitable then would be the 19x9.5 +42 running a 10mm spacer - but the really conservative offset doesnt give a huge amount of pull on the spokes.
Obviously the 19x8.5 +22 is perfect within the guards, but not enough pull....
Just wondering where in Adelaide would be a good place to take my stagea for a awd dyno?
They seem to be few and far between, Ive only had mine up on Willall's dyno - apparently thats the closest for me (and it aint close by). Ive heard there are others down south, but Im not sure on specifics.
had the stagea on the dyno with the 3076 .82 on.
everythn standard besides
exhaust 3 inch
fmic
pod
nistune
made a nice 240rwkw on 11psi.
cant wait for injectors pump and afm. im planing to run 17 to 18 psi and should make the 300 to 320kw mark. il let yas now how i go once i finish the mods.
    • It's worth looking at Neil's garage thread, he was super organised (as you'd expect). He had a simple bunnings narrow shelving rack with tubs, each tub numbered, each number had a manifest. Of course, only about half the parts had made it to that system, and he had random stuff from old projects like kawasaki triples and even a Bultaco (a wtf? I said). I really don't want to throw stuff like that because it is irreplaceable, but it's also hard to know who could use it without spending a heap of time I don't have on research. Not co-incidentally, I've recently decided to try and move on some parts too, either random non-skyline stuff like S13 axles or anything R32 that I had more than 2 spares of (yes, I have a lot of space and a lot of spares). Most of the stuff is on commercial racking which is too deep for practical use for loose spares. Where possible stuff is in plastic tubs (various sizes) to keep critters from eating them. The whole place is a disaster for the poor person who has to clean it out when I'm gone. For the R32 spares, I aim to have one ready to go spare (eg rebuilt gearbox, engine, driveshafts, hubs, control arms etc) and one ready to prep spare.  Even so I've ended up with lots of 3rd or more spares and I'd rather see someone else keep their car on the road. Also I've ended up with some interior stuff like boot trims and floor mats I'll never need. So, I'm about to re-enter the painful world of online selling. I'm not on facebook (and won't be) so that is not an option, I'll start a thread on here for R32 stuff and people who need something can find it. I don't really need to throw anything for space reasons, but I somehow doubt the Greddy Rebec III will be in high demand. Oh, and I've got heaps of bench space and heaps of racking.....but still the bench is covered in half done or about to start jobs, I really need to get it better under control but time is an issue
    • This is the current antenna, 4g bands are the ones I'm after, particularly the Telstra long range one which I think is 850Mhz? It has an SMA connector to a 3 way splitter, one runs to the Cel Fi and 2 to a USB 4g wifi stick The problem is not the antenna, the problem is that the V37 has a slightly smaller gap between the rear windshield and the body which prevents the line from being tucked away under it as it was in the Fuga. Therefore, I have about a meter of cable that I can't adequately secure running down the outside of the car to enter the boot....I figure I need to use a roof mount antenna instead and run the cable inside the car The other option I'll look at is removing the factory shark fin (which I assume is factory GPS, which is crap, I use TomTom app on my phone) and I'll bet there is already a hole in the roof under that I could use. Any alternative approach is very much welcome!
    • Hi everyone    any help? Revving upto 3k   Checked tps  0.48  &  Throttle working alright.   adjusted throttle bolt also   tried unplugging tps but still same   Nothing changed still revving same IMG_1261.mov
    • Thanks Komdotkom, I would take you up on that offer, but the cost of shipping to NZ would be horrible.
    • So what I hear from Rob and Mark is, Matt needs to stay the hell away from your places when you choose to do cleanups, for fear my hoarding will get worse, as Ill likely find things to suit some of the projects I want to build... As for ditching stuff like Mark does, I wish I could do it so easily mate, but lots of my spares are for the R33 and I'm slightly attached to them...   However, I was staring at the pile of subs, 2 for the car, 2 for a home audio system and thinking I'll likely just ditch those... That's. A lot of space back...   I must hurry up and finish the Subaru, and then the skyline... That's probably get some space back...   But my main take away is, other than big plastic tubs, and some sort of categorising what you have in each, no one has found a good solution, that takes up the minimal amount of space possible?   And Rob, I've been wanting a mezzanine, and have been tempted to put one in, but I'm borderline not enough height, and secondly, I hate heights! (No good spot for stairs, so it'd either be fold up stairs, or a ladder, of which I hate ladders and can't carry the bigger stuff up).
