I got 176.2rwkW on the same dyno as Duncan, same day so the results are directly comparable.
GReddy return feed cooler, Apexi PFC, GReddy Profec B Spec II set to 12psi and full turbo-back exhaust - standard turbo on unopened RB25DET. The knock sensor was going crazy (but the engine was not knocking) and the AFM was out of resolution.
Next year will be brakes, then upgrade turbo, injectors, Z32 AFM, and replace that knock sensor.
Last run: 0awkw or near enough to it....
Hoping for something closer to 400kw@wheels once its rebuilt and run in: hopefully by around Feb 2013, assuming we don't all cease to exist on Friday... ;)
Prior to this, it was running 298awkw
Ouch! Makes me think twice about pushing for 330kw on thursday, what was the cause?
Edited by GTR260
nah push away then you can join the lonly I made over 300kw club in my c34 and nobody wants to know lol.
will be turning the wick up in mine early Jan hopefully see 360rwkw stock bottom end 25 yeah yeah.
We'll see how she goes, compression on it is as good as the day it was built soo for all I know she may have been rebuilt at some stage when in Japan. Not going to go past 20psi as im using the built in map sensor on the pro plug in. As for the no one wanting to know about u making over 300kw, they are just all jealous that they are struggling to make it close to 200kw. Lol,
Edited by GTR260
1998 Stagea 260RS
Standard bottom end
GT3582R .82 external gate
custom steam pipe manifold
3 1/2 inch from turbo to cat 3inch cat back
xspurt 1000cc injectors
standard head & cams
haltech platinum pro plug in
bosch 044 in surge tank
standard gtr pick up in tank
turbo tech boost controler
407.4 HP (303KW) @ 20PSI on caltex 98 safe daily driver tune
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
