Is your car a S2? If you have a neo motor I would have thought you would be producing closer to 200rwkw. (I am only guessing this based on the level of mods between your car and mine looks similar)
S1 so non neo engine.....
atomalty,
I made 265rwkw in mine, my mechanic installed every part from stock and is just right around the corner form R.E Customs in you wanted to pop in and get hime to work on it.
It was a brilliant car to drive when it was finished.
Ooo pm me the contact. :)
RS4S opens up lots of choices for ECU's from PowerFC, ViPEC, LinkG4, E-MU, Nistune etc.
standard turbo, exhaust, FMIC, a little more boost usually = around 200rwkw +/- 10kw (remove the front driveshaft for 2wheel dyno)
AWK won't be that different but subtract a few kw's.
pull the front driveshaft and back to back test it on the 4W dyno then we will all know the difference on a stagea. :)
i'm leaning towards the nistune.. anyone else got a nistune on their RS4S ? :cool:
where would be the best place in Melbourne to get one installed? (RECustoms? :P )
or is there anyone else who would reccommend something else? (for a similar price) ;)
i'm leaning towards the nistune.. anyone else got a nistune on their RS4S ? :P
where would be the best place in Melbourne to get one installed? (RECustoms? ;) )
or is there anyone else who would reccommend something else? (for a similar price) :)
Status Tuning in Dandenong.
Trent (URAS on here) does a heap of different ECU's and piggybacks.
^^^ yeah what he says.
talk to trent about what you want and he is more than qualified to match an ECU to your needs.
nistune was not an option when i installed the powerfc on my RS4S plus i have a powerfc and datalogit already for the R33 so this was the best option for me at the time it went in.
You're making over 400bhp already - what else do you have planned for it?
hey :thumbsup:
got 8x S15 480cc injectors already, and a remap planned with Toshi.
just need to save, then will have 2 chips - 1 for stock inj. 240rwkw & 1 for 480cc inj. 260rwkw
:banana:
  • 3 weeks later...
or is there anyone else who would reccommend something else? (for a similar price) :P
Very, very impressed with 'Springy Motors' at Springvale. Speak to George - he's a legend. Got my car back yesterday and it goes like a new machine! See the results of my setup below:
2000 Stagea RS-Four S
'Nistune' computer + tune
3" turbo-back (JJR front pipe, Catco hi-flow Cat, and HKS Hi-Power Silent cat-back & Calsonic Hi-Flow Air Filter)
Cooling Pro 'Stealth' FMIC (Finally got this fitted correctly at Springy too!)
Boost tweaked to max. spike of 14psi.
I didn't think was too bad a number for 4-wheels! I'd be happy to PM you with more info, Atomaly.
+60 kw with a tune? That's a fantastic result. All s2 owners would benefit from getting the nistune as early as possible so as to gain maximum benefit from each subsequent mod!
Although it is a pretty amazing increase, the 125kW figure would have been a bit higher before I put the FMIC in (I had a cooler pressure leak and a split hose at the bleed-valve). With the stock setup, the power didn't dip off that noticeably in that range. I might have gotten around 140kW originally, but still, an increase of even 40kW is just awesome! The car feels great now - you can really notice the g-force kick after about 4,000rpm now, and you can feel the four wheels just getting the power down in lower gears without breaking traction. Stoked with the outcome. Highly recommend the 'bang-for-your-buck' value of the Nistune. There's no gizmos or adjustment in-cab, but I didn't want all that anyway.The results speak for themselves, and the car is now setup specifically for my mods.
  • 1 month later...
Well I have finally reached the limits of my current sidemount at 225.7 AWKW. Car was making more power but smic was getting hot so current tune is the safe setting. I conclude that the GTT or s2 smic is good for about 220AWKW but you would probably see benefits from a front mount from about 200AWKW onwards (i.e. when you replace your turbo). In my case I am going to stick with the smic but I'm looking for an ARC one which should enable me to retune to 240AWKW which will do me for now. Car seems very fast now (80-120km/hr in 3 seconds flat) and I will try to get a 1/4 mile time this summer ( won't be that flash but Í am interested to know).
Relevant mods (excluding the thousands I have spent on suspension and brakes):
76mm exhaust with split dump and no cat (still a bit restrictive as very quiet)
Stock turbo highflowed by GCG
Walbro fuel pump wired to full battery voltage.
550 DeatschWerks injectors
Z32 AFM
Nismo smic (similar in size to GTT but allegedly slightly more efficient)
Pipercross panel filter in stock airbox
GReddy adjustable exhaust cam gear (set at 3.5 deg ret so 4 deg pretty muuch OK)
Jaycar IEBC set at 1 bar
R32 ecu chipped by X-tune and piggybacked on to stock ecu.
Thanks to Joe (Joe's Mechanical Services) and Andy (X-Tune)
I'm not the expert! Z32 was an option but Andy the electronics whizz chose the R32 one. There was a heap of work involved. If I did it again I think I would go with either the Greddy E-Manage or get a wire in Link (Vipec).
Very nice power - what boost are you running every day on the road?
Its not an everyday road car but at the moment the profec b is set at 1.2 and 1.56 . I have the Greddy remote boost switch on the steering wheel which swops it over at a touch (definately the best toy I have ever bought :banana: )
Edited by RSVFOURUK
Well I can't compete with those 500hp+ figures from the UK, or Tangles' awesome S1, but here are my 'before' and 'after's. First one was done at my 100K service and was completely stock apart from a K&N panel filter in the stock airbox. Then there were some mod's, and a re-tune. I am very happy with the result so far anyway.
Before:
After:
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
