RS4S - Power FC - Blitz zorst - Greddy fmic - Hks pod - T piece boost control
150 awhp std ecu (surging and slurping)
173 awhp untuned pfc
194 awhp @ std boost - tuned PFC
206awhp @ 11psi - tuned PFC
Edited by RED513
There is a thread for Stagea Dyno charts in the DIY sticky above labelled "Stagea Dyno Results" .
Well after the sh1t-tacular results of sticking the C34 on the dyno I thought we might like to make a thread to post stagea dyno results in. ( or lack of results in my case !)
Any suggestions/comments are welcome ( positive of course ! )
116kw Stock auto s2
146.2 3inch turbo back, air pod, front mount.
138 3 inch turbo back, front mount, stock air box.
129.8 3inch turbo back, air pod, no front mount.
next will be with front mount, nistune setup, and new gearbox solenoids
ssshonky.. our results are crap.. 222awhp @ 12-13psi through a hiflow when people are pulling nearly that with stock turbos.. just about everyone was 100hp down.
I shall blame the 38deg day and the Haltech pulling heaps of timing!
Edited by bubba
first mods:
second stage:
third stage:
fourth stage:
fifth stage:
sixth stage:
seventh stage:
eighth stage:
issue being fixed on 6th january - adding stainless lowmount manifold, 4-pot brakes, engine oil cooler kit, wideband afr meter & oil pressure guage
expecting to see 250rwkw now Ive sorted out the rpm cut as seen on 7th stage
Question,
How many KM's are you planning to get out of that motor? and how often will you be driving the car?
Is it ever likely to blow up? (I'm unsure whether im asking stupid questions or not here) humor me though? :)
Thanks for the support- I was feeling hell emo ! I almost put a black fringe on the stagea so it could be Emo too. Well - To be honest its a good outcome from a bad dyno run. Loretta finally realises she really needs to chuck some $$ at the car to get it running to its full potential. I thinkk she is going to be happy with the results from essentially what she already has!
I compare it to an athelete getting fat and out of shape , with a bit of work he/she can be back to full potential - kinda the same with the Stagea
we wont know anything till the 5th of Jan - so stay chooooned for an update
MacDog- valid questions, but most tuners will be pretty sure to run a safe tune( Ie dont make it go too lean ) so in theory sure you will get more wear and tear from pumping more power out but as long as it does not lean out you should be ok.
Cool,
Next question, have any of you guys Blown up a motor?? :3some:
Question,
Is it ever likely to blow up? (I'm unsure whether im asking stupid questions or not here) humor me though? :3some:
hey mate. Ive had her for near 5yrs, and plan to have her for a further 15+.
sees the road every week, and the Hills every 2nd weekend.
sees the Hills very nicely indeed :D need a nismo speedo
the motor will be there for the time I own the car, she aint' gonna blow.
one day in a few yrs time I'll do the final stage of tune and complete the bottom end, but that'd just be for kicks not necessity
would expect 270kw once complete
also, I'll be self road tuning after the next dyno tune on the 6th january. adding in the wideband lambada sensor kit,
so my laptop can feed me the data while driving and adjust maps to suit.
cant wait tbh :/
Cool,
hey, my fist bike ping'd its face off. a gpz-250cc couldnt take all 115kg 6'8" of me :/
I had to rebuild my Fireblade many moons back due to glazed cylinder bores; caught it early, could have onsold without issue but that'd be bad karma
so I threw 12g over 4yrs into it and enjoyed every km thru the Hills. very capable machine that one.... 300 @10thou rpm top gear. often
never blown a car engine tho.
dont plan on blowing this one either, Im sure Ive done everything right along the way to ensure now that I'll be selftuning I wont f**k anything up.
ie the vehicle in a whole complete form can take it.
as it is the rb25 + gt3076r has loads of punch thru the twisties : will look forward to hardening it up a little more with the bottom end build and then she'd go like the clappers
not that it doesnt now, very bike-like in the Hills.
:D
  • 1 month later...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
