where can i go for a cheap dyno run??? pref AWD, i remember back on the VW forums, when we had meetings the dyno days were 50 bucks, lunch etc all included. but that was a dyno day, i just want a dyno run.
anyone in sydney?
all runs in RWD >_<
Thats a good result from a stock turbo. More kw from now on start to get (more) expensive. Its good to try to work out your ultimate goal to save doing things twice. If you start going on the track/drags the tendency is to want more and more power without end! But for a road car 240kw is a fast car and 260 - 280 really fast.
If you figure that your turbo is going to blow one day then a rebuilt hybrid will get you up to say 220 on its own or 230 - 240 with bigger injectors and a Z32 afm.
If you want 260+ kw then I would seriously consider getting a Link or Vipec - then you can sell your SITC and SAFC and won't need a new afm or better boost controller. But you will need say a GT3076 or Hypergear turbo and bigger injectors and (depending on what you have now) a better fmic. And of course a top tune.
I finally got around to checking my car. Completely empty. hmmmmmmmmm
Do i have a leg to stand on at all with the company i brought the car off.
I'm suppost to be the first Aus owner and arnt they suppost to replace the cat upon compliancing?
What could be the next step in look at why its running 4psi?
I check the piping which comes from a metal pipe that runs around the back on the engine.
Then it splits into 2 and goes to each turbo!!!!!!
had car retuned to after some further mod's
current mod's
nismo fuel pump
nismo FPR
nismo 740cc inj
Z32 AFM
R34 PFC (c/o hills motorsport)
Greddy ProfectB spec II
Greddy inlet manifold
80mm hypertune throttle body
FMIC
Tomei Pon Cams
HKS 3037 kit inc high mount manifold and 50mm external gate
HKS 3" exhaust from turbo back
Manual conversion inc OS Twin Plate
final power figure 387hp at all four wheels on 1.3bar
A HUGE thanks to Sean and the guys at ALLSTAR GARAGE in Malaga WA
current mod's
nismo fuel pump
nismo FPR
nismo 740cc inj
Z32 AFM
FMIC
Tomei Pon Cams
Over 290awkw - should be a flyer! Any plans for a 1/4mile time?
have never run it down the 1/4 mile since ive had the car but im sure i will once the street drag series starts again in WA. would hope to see a low 12 on streets.
  • 3 weeks later...
Had the PNM35 on a 4wd dyno today. Absolutely stock, std filters exhaust, etc etc. Running a VQ35de. Dyno'd at 147.3kw- dynodynamics.
Flat Torque curve, running quite rich in the top end at 11.5:1 AFR
Pretty much as expected, V35's are running a little more, but you take into account auto-slushbox and 4WD loss to make up the difference!
I know, I know!!! Its being processed by the Minister for Finance and War...
Also that was on 95 pump, don't ask, the Mrs filled it up. :(
I had a chat to the guy, he said the biggest improvement he has seen on a V35 is a shot of NOS.... cue Fast and Furious moment... I couldn't believe it. But he said about 100kwatw and no engine damage :)
Prob won't be going back there for any work!
Edited by PN-Mad
I think nitrous is one of those things people are scared of.
Im not an expert by any means, but if you know what you are doing it is a very safe and cheap way to make good power at a very low cost.
Otherwise I can recommend some really nice twin turbo kits for you :( DO IT!!!
I guess thats the key... the consequences if you don't know what your doing are... not so good!
by the way... bbenny, I want your wheels. They are bloody awesome. Apparently they are no longer imported into Aus in that size by Avanti. I have an epic price on RPF1's in that size, but i don't think they suit. thoughts?
Yeah I was lucky enough to pick those up overseas at a steal! I was considering RPF1's they are much more understated, but look so tough!
With the RPF1's you have to get at least 9.5 wide of they have a really flat face - they need pull to look any good. Which is tough because the only one suitable then would be the 19x9.5 +42 running a 10mm spacer - but the really conservative offset doesnt give a huge amount of pull on the spokes.
Obviously the 19x8.5 +22 is perfect within the guards, but not enough pull....
Just wondering where in Adelaide would be a good place to take my stagea for a awd dyno?
They seem to be few and far between, Ive only had mine up on Willall's dyno - apparently thats the closest for me (and it aint close by). Ive heard there are others down south, but Im not sure on specifics.
had the stagea on the dyno with the 3076 .82 on.
everythn standard besides
exhaust 3 inch
fmic
pod
nistune
made a nice 240rwkw on 11psi.
cant wait for injectors pump and afm. im planing to run 17 to 18 psi and should make the 300 to 320kw mark. il let yas now how i go once i finish the mods.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
