Works good too, brings it all on heaps earlier, just like the grub screw in the BOV. :thumbsup:
I just got back from tuning after fitting the stock turbo, it was only a temporary tune as Garrett is out of GTX turbo's at the moment. Running ethanol and pushing 1.2 bar the stocker made 225awkw and 850nm. I might just stick with this one for a while... :cheers:
This is a good representation of what a stock turbo (17psi) and a stage 2 (20psi) can do on ethanol, overlaid on the same graph. Cihan was very impressed with the stockers capabilities.
That's very impressive. How long would you expect the stock turbo to last at those pressures? So much has been written about short life expectancy if over 14psi. Is this temporary return to stock a bit of an experiment where you don't care if it lets go Scotty?
I would prefer if it didn't, and I only raised it 2 or 3 psi, should be ok.
I have an opinion on the failures, it seems to be the rear bearing that goes, possibly caused by oil starvation. The oil restrictor banjo bolt only has a 1mm hole and could easily block, especially if the engine internals are dirty. As mine has been flushed, I am hoping it will last just fine. It doesnt sound noisy like they usually do.
It could be a good idea to flush your engines and then check the hole isn't blocked...
I'm not tuning, I'm fabricating a stand for the extraction fan I gave him, the 1m blades should do the job nicely. I wont say what it will suck like... :)
Do you want me to make another modified actuator?
I'd love to know where exactly this is so i could check. Is it on the block or turbo? Is it recommended to drill the hole out to (say) 1.5mm or does that cause other problems?
I'm very keen to make the std turbo last as long as possible and, given your results, it doesn't look like I need to put up with low power. Not saying I will run boost that high though.
It only made 2kw more with the higher boost, but 100nm extra torque.
The restrictor banjo is in the block, you can just get to it with a (17mm?) spanner. Don't strip the thread putting it back in... I dont know if drilling it out will be too much for the seals, probably not, perhaps you should just check it to make sure it is clear.
I think Scott's been drilling the hole to 3mm
Mmmm, 300% increase. Sounds like Scott :thumbsup:
Thanks Scott. You posted at same time. I will check that it is clear in the first instance. Maybe discuss improvements later...
Edited by Commsman
He'll have to answer that one LOL. Banjo bolt...somewhere on the turbo..?.:/
or not...:blush:
For some reason the song "The devil went down to Georgia" springs to mind. But I digress.
scotty,
Nice result with stock turbo, didnt think they would like running at 17-20psi, are they ceramic wheel?
Also your dyno graph doesnt have the power dipo at 3500rpm??? Do you run stock converter/trans?
Yep, ceramic but much different design to the Skyline/C34 wheel, ours run at 1 bar stock where theirs blow at over 12psi apparently. That is where the worry comes from I think as not too many of us have been comfortable with ramping the boost on the stocker.
Nope, My transmission has had a full build, still a work in progress. The 4000 stall dominator made me is a little too open, the factory lockup clutch you see in the dyno graph wont work and just slips as it is trying to haul in 1.5 - 2k revs (which it just cant do). I have disconnected the clutch for street and installed a 12v switch direct to the solenoid for dyno runs. It holds well over 1100nm of torque that way, I had it slipping at 24psi on my old turbo so im not sure where it will crap out with the Garrett GTX.
I am trying to source a spare torque converter to cut open, they are hoping to find as direct a replacement as they can to allow a larger clutch and more efficient stall stator to be fitted. Perhaps the Patrol TC may fit? Let me know if theres a spare M35 one around as this will be an issue for anyone building their box eventually.
So much more power where you can use it on a day to day basis.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
