  • 3 weeks later...
  • 3 months later...
Figured I should probably throw this up for interest sake. In terms of power mods this time around:
- High flowed turbo
- Impul ECU
-* Plenumn Spacer
-* HDi FMIC
-* 3" exhaust dump / cat removal
-* K&N Filter
The *'d items are 'new' compared to my old 173awkw, so not a huge difference in terms of 'top power' but the power delivery is completely different - much more power early on in the curve, on decent boost heaps earlier.
- High flowed turbo
- Impul ECU
-* Plenumn Spacer
-* HDi FMIC
-* K&N Filter
gotta be very happy with that not being tuned yet,
get hold of the actuator mod off scott!
Definitely coming along nicely, its great to see the results and be able to compare between mods - essentially @ 80kM/h I putting down ~20% more power by really only doing air filter, FMIC and Exhaust dump.
More/Consistent boost would be nice :thumbsup:
thats just it, the response of your turbo must be much better after opening especially the dump.
that actuator mod scotts doing gets you on boost earlier, and allows you to hold a better line!
or you get get a stronger actuator with a long rod, and bend/weld to fit!
  • 1 year later...
1999 Stagea RS4S
HKS 2835ProS
Nismo 480cc injectors
Plazmaman FMIC (turnflow)
3" Straight through exhaust with mid muffler and massive rear can (very quiet car)
260 deg type B Poncams
Greddy Profec B
Nistune (car has run with auto base image for around 2 years finally figured out that it was supplied incorrectly and just re-imaged)
Tidy up tune with Jez to check what if any WOT mapping changes were needed after installing the manual image. It is anyones guess what Nistune is doing under the surface. Plus I wanted to work more on getting the car off the line. The Stagea bogs down quite easily unless you give it the beans off the line. Changes made to very low load fueling and VCT has sorted out these issues.
Thanks Bob. The car remains Ms. Wolv's shopping trolley so it is unlikely to see the dragstrip. She will be stoked with the improvement off the line. The car has always had a very quick midrange but this touch up tune managed to pull all the ends together. Jez tipped more fuel in from peak torque and it like it a lot. Each degree of timing was making big jumps in power. The neo's seem pretty sensitive to using fuel to cool the cylinders compared to my R33. No doubt E85 would be brilliant with this engine but it is impractical in Sydney at this point in time both for availability, cost of changing injectors, ECU, flex fuel sensor and fuel pump.
Changing to the manual image on Nistune sorted out some issues with throttle recovery and general smoothness which has been quite annoying for the last year or so.
  • 3 weeks later...
s1 with neo and manual conversion.
3076r. 63 exhaust
38mm turbosmart waste gate
type b poncams
1000cc Bosch injec
nistune
044 external
walbro int
surge tank
extrem 6puck clutch
cooling pro return cooler
trust oil cooler
Mls head gasket
arp head studs
3" turbo back exhaust with nismo muffler
just need to stabilize boost and clean up under the curve but should have a bit more in her b4 exhaust housing runs out. but heaps of fun already
hell yeah e85 would not see that power on 17 with pump. reckon I can can get about 350 with a bit more playing but the .63 should choke about then. also about limit of the g box
  • 3 weeks later...
Just got my NISTune done:
Series 2 C34 with a boost controller and a home-made dump pipe. Not an amazing result, but not too shabby either considering the almost total lack of mods. Around 120awkw @ 3000RPM is nice with the weight these things are lugging around. Torque curve goes up at 2500 and then flatlines to about 5800, so she's very pleasant to drive. 13 PSI @ 2500, flat line down to 11PSI at 6000.
Edited by joorsh
My M35 made
168kw @ 17 psi
Had to bring boost back as it was pinging due to crap fuel.
Settled for 155 on 95octane @11psi (What i get for being out in the middle of no where with a shit servo around)
Not hard to fix
It's got:
full 3" impul Exhaust
Scott dump
Calsonic front mount
Impul ecu
Stock turbo
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
