Thanks munch, i know the stock quarter times on a stock 33 gtr are 12.6, and a stock rs260 is 12.9, so there not alot slower for the weight difference, but with my exhaust mods and double the stock boost i would hope to see some improvement over stock power outputs. Any power listings for any of the high power jap cars always seems to say 206, which ive been told is an understatement even from factory, thats why i wondered what an accurate guess might be. I need to find time to get to a 4wd dyno, but as far as i know none are on my side of town. Can anyone suggest anywhere with a reliable 4wd dyno in adelaide?
The "stock" R33GTR is somewhat more "stock" than the 260RS. The 260RS has better exhaust from what I have seen and runs a coupla psi more boost.
:) cheers :D
Edited by Sydneykid
what type of dump pipe are you running? split,blended,or std? what else is done to the car?
where it runs really rich up top would make sense if you have an atmo BOV,and the majority of the curve makes sense if it's a std ecu on a car with the usual mods (exhaust,FMIC,etc).
mine has an exhaust,pod,and boost controller,and it doesn't run quite as rich as yours does,and makes more power. I would put it down to the intercooler,and any differences in our exhaust systems,particularly if you run a blended dump pipe,as they tend to run richer on cars with std ecus.
Justin...
andy, can you list the mods. looks like the ecu is hitting R&R.
fergo, what difference would an atmo BOV make on WOT? as i understand it'll run pig rich when you close the throttle but i don't understand why it would run rich as you have described.
you know u need that powerFC now....
any ideas why my air fuel ratios are so rediculous?
I thought you got a new AFM? And it cured it.
I've just run two tanks full and averaged 151/2 per 100. Mostly tip toe stuff, but I live in very hilly area.
Got a Dfa to put in and thinking wide band O2 and after you mentioned AFM was considering that also.
Now i'm confused
Remember I'm new at this.
Edited by 66yostagea
i thought it was fixed after i changed the AFM but i think it was just a case of heaps of highway km's and mostly babying the car when i drove it during that tank of fuel.
mods are;
boost controller set to 10psi
GFB Stealth FX BOV
Front mount intercooler
split dump/engine pipe
5" catco metal inside cat with 3" reducers
BLITZ NUR Spec cat back exhaust
K&N panel filter
yeah i know i need it, but im a long way off from being able to afford it.
that's exactly what i was referring to,right at the very end of the curve,where it the power tapers off quickly and it dips mega rich. he's lifted off the throttle at that point,and the bov has vented,causing it to sink into the 9's for mixture.
I agree,it needs a power fc to lean it off safely.
Justin...
HOLY RICH AFR'S Batman! Wow!! I though a jaycar AFC thingy could fix that, or something like an SAFC(II)??
Why go out and spend big on a Power-FC when I would've thought a SAFC could do the same job and a quarter of the price?
My AFR's are that rich or worse when I did Dyno full power runs. My car is standard, but I was running 'high' boost mode all the time. My max power was up closer to 7000rpm though, not 4500rpm. And my car uses obscene amounts of gas. I've got a wideband AF setup to install and get my head around exactly what my 'standard' mixtures are doing. If I run more boost, it misses when it hits 9psi, but I know it'll be 10:1 or so around there, so maybe its a rich misfire. Shouldn't be detonation I only run 98octane and 9psi so it would be hard.
Will be very interested to log some driving with the Innovate LC-1. Does it seem lots of Stagea's are this rich? Like 10:1 at top end. Nissan wouldn't do that, its outside all tuning theories I'd think.
At standard boost they are rich (11 to 1)
Turn the boost up a bit and they go richer (10 to 1)
Turn the boost up a lot and they go megga rich (9.5 to 1)
Then they go R&R mapping (9 to 1)
It's normal, that's the way Nissan tuned it with safety in mind.
:nyaanyaa: cheers :laugh:
Great Info!! Thats put my mind at ease, could the 10:1 cause a miss do you think? It works through it ok and rpm continues to climb, but I guess this could be as boost is dropping back to 7-8psi(due to pneumatic boost controller).
What does R&R stand for?
apart from the obvious, is there any difference between tuning your stag on a 2WD dyno compared to a 4WD dyno?
how do you plan to tune on a 2wd dyno,when the car is 4wd? pulling out the relay will burn out your transfer's clutch packs. I wouldn't recommend that.
Justin...
p.s. Wolverine: because the power was already tapering off. no point in going any higher if it's making less power.
Edited by fergo308
  • 5 weeks later...
Hi All,
I have 1997 RS4 (Auto)
- GCG HiFlow Turbo
- Hybrid FMIC
- Walbro 500hp intank Fuel Pump
- Turbosmart Eboost EBC 7psi 10psi 14psi
- Turbosmart FPR (Street)
- K&N Pod with cold air induction
On a Dynodynamics 4WD Dyno @ APC in Brisbane
203 kw @ all 4 wheels! 3rd gear :sorcerer:
made roughly 100kw @ 3000rpm :happy:
made roughly 200kw @ 6000rpm :)
Have no issues with factory ecu (maybe its chipped?)
Dont think I will bother with piggyback or aftermarket ecu's
The guys at APC rekon with a Haltech I could get in the 250AWKW+! :laugh:
Need about $3k for that though....
Wade
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
