Wade sorry to say but I dont think that is a true result.
Your mods are exactly the same as mine apart from a full exhaust which I had with a split dump, highest flowing cat around and 3inch catback and I only made 160awkw.
Maybe it was an optimistic dyno? Sorry I dont beleive you, but please post a dyno graph.
Hello People,
I will arrange to get the dyno image scanned...
For now I can tell you the following:
In 3rd gear on APC's 4WD Dyno: 1st August, 2006! (RECENT ENOUGH)
75kw @ 2400 95kp/h
100kw @ 3200 115kp/h
125kw @ 4000 135kp/h
150kw @ 4800 150kp/h
175kw @ 5600 160kp/h
200kw @ 6400 180kp/h
203.8kw@6600 190kp/h :sorcerer:
I promise you guys this is not bullshit! I watched them do every run
as they were tuning in my e-booost boost contoller...
They also put new platinum spark plugs in before the run.
Anyways I will post actual dyno sheet the moment I have the scanned file
Till then...thanks for the kind words to those happy for my result!
Maybe just maybe reading my mods and results might save some people some money!
I have had 200sx/ Supra/ R32 Skyline all 12sec-13sec cars
I feel as though the Stagea is feeling like a 13-14sec car
I also have owned many motorbikes my current ZX10R :ninja: has 165hp @ back wheel
and easy 10'S...
I do have half a clue guys...my 32 years on this planet helps!
Wade
Also...
I did ask about whether or not I would see much improvement over the 203awkw if I added
a z32 AFM, the guys said the tunability wouldn't be as good and the power would not increase that much
the best way to go would be an aftermarket ecu and ditch the AFM altogether!
But going an aftermarket will never be as good as factory for smooth running...
Also the power getting up to 250-300awkw will mean bigger injectors
tougher transmission, maybe forged pistonbs etc..
200 - 220kw is a good figure! I think car is much better to drive also, lopes along like a V8 now!
Here is a little camparo:
Stagea 1650kg 320-330kw at the flywheel 17k + 3k = 20k+
911 Turbo 4x4 1650kg 310kw @ the flywheel 200k+
Cayenne Turbo 2400kg 330kw @ the flywheel 200k+
I have leather, ABS, Airbags, Sunroofs, Climate contol etc
This is truly a great car with alot of bang for your buck!
Cheers,
Wade
great work wade, just want to mention that an aftermarket ecu will be able to run exactly like a factory car if the tuner knows what he is doing, and u choose the right ecu. im not sure if your auto or manual. manual is easy as u can use any ecu, auto is rather tricky though.
cheers
Edited by CruiseLiner
Thanks guys! I wouldn't mind fattening up the midrange power a little more...
Do you think looking at my dyno results that an SAFC would help me get some
more midrange and maybe even a little more top end power?
Once the boost gets past about 12 psi the car really takes on a different personality
it feels really quick above 4500rpm and 12psi+ boost I have seen 16.5psi
on my e-boost peak hold function.
There really is no difference between power made between 7psi setting and 14psi
setting before 4500rpm (approx). (Maybe an SAFC might help with this too?)
* Although it isn't such a bad thing not making huge power down low (petrol$$$)!
I will try to find out what if anything has been done to my ecu, as far as I can see
it is all stock and I can definately assure you the previous info re: my mods is
100% correct!
I don't have a chart with AFR's I will see if the guys can get me one though...
In the meantime I can tell you taht AFR's were pretty much between 11 and 12
The guys were telling me the car is running 'SAFE' as!
Go champ!!... so your Stagea actually feels quick? :D cant wait to get the rest of my mods fitted and tuned :( ...did you install your eboost? and where did you mount it ..i need to fit mine this weekend but its so damn big i dunno where to mount it and still keep the factory look interior
Top of steering column of-set to the left, you can still see speedo needle
all your gear lights and tach, plus all warning lights, turn your ignition as far as you
can without starting car that way you can see all warning lights and position
accordingly...
Mount the solenoid near the factory one I guess easier with hoses etc..
*You might want to locate it to be a bit more stealth, just make sure all hoses
are on tight!
wade if the afr's look good then a SAFC won't help much.
although if the afr's look good at that level of flow it is surprising the factory ecu didn't go much fatter.
if the car went thru 180kph to 190kph does that imply the ECU speed limiter has been tampered with and possibly the ecu is not standard?
203awkw should keep you happy.
Still not sure about the ecu?
With regard to speed...maybe the extra speed is just momentum
but, like you say if it isn't maybe that is confirmation my car has been chipped...?
The car was totally stock when I bought it but maybe it just appeared that
way because they put all standard parts back on for ADR's...
I am certainly happy with my current result, just wouldn't mind a little more
fine tuning to beef up that midrange between 4500rpm -5500rpm
basically I would like to reverse the hump and make it a bump! Ha!
Do you think an SAFC would be capable? (Relatively low cost mod.)
accordingly...
are on tight!
Cheers mate!!
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
