Winged/Gated sump is where the sump has one or two flaps which act as trapdoors to prevent oil starvation by the oil pump. Usually fitted by drifters and racers because the violent movement of the oil whilst racing adversely hinders oil pickup.
https://www.sau.com.au/forums/topic/52561-busted-sump/#findComment-1035481
If you have a RWD GTST then id stick with using the std sump, unless fo course you have spare cash tehn sure go ahead but i think there are other areas of the std RB engine that need help before the sump. LOL, also keep in mind that with a bigger sump a simple thing liek your regular oil change may add up to $100+ due to the capacity increase:(
https://www.sau.com.au/forums/topic/52561-busted-sump/#findComment-1035934
I might be wrong...so call me stupid :)......
I think the engine has to come up or out to take it off...the oil pickup sits into the pan a bit though a hole into the bottom...
Bit of one of those jobs that are a pain in the butt.....like every god damn thing else that needs fixin :bahaha:
https://www.sau.com.au/forums/topic/52561-busted-sump/#findComment-1036049
Im not sure on the GTS models but on the GTR it can be done without removing the engine, however at the end of the day it will cost you around the same in labour. Involves pulling the gearbox off, removing the front cross member while holding the engine in place with an engine stand, quite alot of work.
https://www.sau.com.au/forums/topic/52561-busted-sump/#findComment-1036155
nar u shuldnt hav 2 take the motor out, easier 4 gtr coz frnt diff goes thru the sump.
dnt quote me, but the last time i checkd, u jus take out all lil sump bolts (10mm) n the 2 reinforcing mounts on eithr side 2 bolts on box n 2 on motor eithr side (12/14mm soz cant membr), n the gbox cover plate to make it easier 2 get 2 bak bolts, may need screwdriver 2 break seal ov factory glue (dnt scrap hole in sump/block) n then a bit ov manouvoring around the oil pick up inside n the cross membr underneith n then wolah! off.. but youl proly find u might not b able 2 get 2 the dent, proly hav baffles in ther, but cant hurt lookn. GOOD LUCK.
https://www.sau.com.au/forums/topic/52561-busted-sump/#findComment-1036156
Ok, Ill take a shot at it tomorrow - Just a warning that I have no idea what i'm doing..
- Take out All the 10mm Sump Bolts
- Take out 2 Reinforcement Bolts (Located at the front?
- Take out 2 bolts on box (Where ever these are?)
- Take out 2 Bolts on motor either side (12/14mm) (Again, whereever these are?),
- Take off Gearbox Cover Plate
- Take out Back two bolts
Think thats what you were trying to say in your instructions :)
https://www.sau.com.au/forums/topic/52561-busted-sump/#findComment-1036257
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
