Cheers Chris - that was great you doing that.
I'm just trying to track down a stock setup. A guy in melbourne on these forums has the stock BOVs but not the piping...I'm wondering how hard that will be to get ...
Here you go, just took them for u now.
I have a POD filter on my car. Dont think it has any influence on the Blow off valve. The stock setup is just putting it on the stock pipe. Making sure the Plumb back pipe is connected and that the smaller pipe from the BOV to the Manifold is also connected. And it should be fine.
Seems like my car has the standard BOV still connected with all the hoses (doesn't appear to be tampered with)...plumbing back into just after the POD
How can this be. Do some people add a HKS while keeping the standard BOV there.
So I can just take the HKS BOV off?
Is the HKS doing most of the work?
Gee these are nice motors.
It would make sense using both bov's though as a means of utilising the designed in 'leak' of the standard bov for the purposes of keeping the idle working correctly for the standard ECU.
The point I'm not sure about is whether the standard bov would have been screwed really tight to stop the valve from opening.
Yeah it is Chris. Will get the digi out tommorrow and have a better look - but traced all plumbing from the standard BOV and there seems to be nothing disconnected ....
Wonder if this means I can just get that pipe that has the HKS on it and replace it..
Both can be connected. I got one friend with an R32 with a HKS one and a stock one connected. This is how it works for him. When he drives the car normally the stock BOV works normally and there isnt enough pressure to open the HKS one. When he full on floors it then the pressure is higher and then the HKS BOV vents the pressure. If everything is connected i dont see y it wouldnt work. look foward to the pics :(
