Light has come up on my dash this morning. RH side of cluster, bottom row, on the very left. It looks like a house with long windows kind of?? To the left of the exhaust warning light and oil light. Might get some pics up tonight if no one can help out.
https://www.sau.com.au/forums/topic/52631-whats-this-dr30-warning-light/
Low water in your radiator over flow bottle or somethinng along those lines, i overheated mine once and that warning came up, filled overflow bottle back up and didn't have any other issues
i was wondering what that light was for too.. with my conversion the i'm using the r32 over flow bottle and its not conected to the wiring (why bother) i might just remove the bulb. one small mystery crossed of the list...
Is anyone elses battery light on constantly?  I've always got heaps of charge to crank it over and I left it standing for a couple of months and it was fine
My bet would be that your alternator will give way in couple of weeks time. Thats what happened with mine, I believe boof has gone through a few too.
yerp word to that, 4 in a bout 3 months or something stupid!! it results from the regulater being to slow to regulate so kills the alternators pretty quickly i beleive!!
Coolness. The light went off straight away after restarting this morning. Just got home from a 30 min drive back from g/f's house and the light came on for a while, then went out. I checked coolant today and it was fine, but will top up over flow bottle tomorrow.
Hmm... the battery light has been on since I got the car and I've been driving it daily for 12,000km in 6 or 7 months.
You checked that all your wiring to the alternator is connected?? Sounds like some dodgy wiring going on there somewhere maybe, i know when my alternators are going to die, cause all my warning lights on my dash come on, door lights the works!! Silly dr's
The reason that all the dash lights come up is the bulb-check sequence. There is a relay hooked up to the alternator & battery that is only energised when the alternator isn't charging. Hence when your alternator dies, not only do you get the charge light illuminated - all the other lamps come up too (except the high beam & cat converter temp from memory).
The original almp in question is the low coolant overflow warning lamp. Chances are that if yours doesn't work the bulb is gone - I replaced about 4 when I got my DR to get them all working.
The bulb-check sequence reveals all! :D
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
