Light has come up on my dash this morning. RH side of cluster, bottom row, on the very left. It looks like a house with long windows kind of?? To the left of the exhaust warning light and oil light. Might get some pics up tonight if no one can help out.
https://www.sau.com.au/forums/topic/52631-whats-this-dr30-warning-light/
Low water in your radiator over flow bottle or somethinng along those lines, i overheated mine once and that warning came up, filled overflow bottle back up and didn't have any other issues
i was wondering what that light was for too.. with my conversion the i'm using the r32 over flow bottle and its not conected to the wiring (why bother) i might just remove the bulb. one small mystery crossed of the list...
Is anyone elses battery light on constantly?  I've always got heaps of charge to crank it over and I left it standing for a couple of months and it was fine
My bet would be that your alternator will give way in couple of weeks time. Thats what happened with mine, I believe boof has gone through a few too.
yerp word to that, 4 in a bout 3 months or something stupid!! it results from the regulater being to slow to regulate so kills the alternators pretty quickly i beleive!!
Coolness. The light went off straight away after restarting this morning. Just got home from a 30 min drive back from g/f's house and the light came on for a while, then went out. I checked coolant today and it was fine, but will top up over flow bottle tomorrow.
Hmm... the battery light has been on since I got the car and I've been driving it daily for 12,000km in 6 or 7 months.
You checked that all your wiring to the alternator is connected?? Sounds like some dodgy wiring going on there somewhere maybe, i know when my alternators are going to die, cause all my warning lights on my dash come on, door lights the works!! Silly dr's
The reason that all the dash lights come up is the bulb-check sequence. There is a relay hooked up to the alternator & battery that is only energised when the alternator isn't charging. Hence when your alternator dies, not only do you get the charge light illuminated - all the other lamps come up too (except the high beam & cat converter temp from memory).
The original almp in question is the low coolant overflow warning lamp. Chances are that if yours doesn't work the bulb is gone - I replaced about 4 when I got my DR to get them all working.
The bulb-check sequence reveals all! :D
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
