Thor surging is generally not a problem amongst a stock turbo running stock boost.Though check ur fuel filter how long has it been since u replaced it? and chek that ur plugs are gapped right and give them a clean cause maybe the problem lies not in your turbo surging.
I think that it is 5psi stock boost or somthing like that.
https://www.sau.com.au/forums/topic/52638-needing-advice/#findComment-1035796
