  • Replies 44
So how many N1 were sold...no f**king idea but as far as the true enthusiast are concern the true N1s were the Race Spec ones sold in 1991.
nicely researched answer there :(
But personally its the Vspec II N1s that are the pick of the bunch because they had the larger tyres 245/45/17s
nicely researched answer there :cheers:
Dunc you know which "true" N1s he's talking about?... he's talking about the 55mil yen homologation ones... ab-so-****in-lutely the ultimate R32 GT-R from factory. But for my money I'd agree with you, Vspec II for sure :aroused:
Ok I know its not hard to do but you've REALLY confused me with the whole R33 N1 number calculation, i was under the impression they only were made in 1995? Are you saying that 6551 R33 N1s were made?
Burto... aaaah.... I'm still not convinced the number was that high. I thought that number was for total GT-R units made in 1995... or something like that.
In just about all of the GT-R Magazines they list the first and last chassis number for each model and also build numbers for 32 33 and 34 and all it has for R33 GTR V-spec is that 6,551 were built and this includes N1 models so it doesn't actually have a seperate figure it does for r32 with 228 N1's and R34 with 45 N1's.
YES according to these books and for the V-Spec and V-Spec II its another set of numbers...if you like I will scan them up tonight.
I need to remain the unanimous informer...
Does everyone vote Troy the unanimous informer?
...everybody? Ok... it's unanimous then...
Troy we all voted that you should be SAU's "unanimous informer"... :rofl: :Owned:
Btw, the "JN1GAPR33" chassis code is for the 100 GT-Rs that were officially sold in the UK.
Dont think any GTR or GTS-T came with chrome headlights. Only 4 Door R33 Non-Turbo?!?
hey is talking about the surrounds inside the headlight, series one are black and the surrounds on series 2 gtrs are definetly chrome (or shiny stuff that the reflectors are made of)
have a look at two side by side and you will see, but it isnt something you would notice from a distance or a quick glance :rofl:
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
