Just thought i'd butt in, i'm in Sandringham just near the old Red Bluff Hotel, and i'm always up for a bayside cruz... Wine red R32 with drift style 3" exhaust. Travel down beach road nearly every night coz of work being in Port Melbourne.
Matt.
  • Replies 44
hey hey!! you're the first other Sandy person i've seen post here :D
oh yeah, i know where that is. Great spot. I'm in Nelson st. I can't believe i have never seen you? Only 32's i've seen are a silver one, JLL11 (something like that) plates, he use to be on here. And a gun metal or black 32 GTR that use to be in Hampton street a lot but not anymore.
I work in South Melbourne (above the BMW car yard, Neiderlasung) but only drive down/up beach road on a Sunday. Like 3:00pm and then back again at 12:00am (midnight) - So i prob miss ya.
Oh well, when i get my car, we'll definitely organise something for the all the bayside peeps, i've never really seen anyone else post here from down our way so it's good to know there are some Sky's around :P Looks like you might be Skyline-less soo tho?
Yeah, only moved here in March this year, but used to be near the Dan Murphy's on Nepean Highway, so i've been close all my "skyline" life of just over a year. But you're right about being skyline-less soon, going over to London in January, so the car must go. The extra money won't exactly hurt while i'm over there either!
So the sooner we organise a big bayside event, the better. Coz i work at "Auscarts" in Port Melbourne, so maybe a cruz along beach rd, then up to Port Melbourne for a bit of go-karting..... Just an idea anyway.
Matt.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
