R32 GTR test drive
Originally posted by GTRKING
Does he STILL have the silver one with all the mods?
If so he has had that car for more than a year now!!!
and has used it on the track numerous times.
LOL... About 6 months ago I was going past Phillip and that silver R32 GTR pull out of the car yard and he gave it a bit. Then when he saw me putting along in my GTS-t he gave it heaps, and I mean HEAPS.
Now I'm not sure if it was cold or what, but the amount of black smoke that came out of the exhaust was amazing. It looked like the Batmobile there was so much smoke!!!!
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-81817
all gtr's either 32, 33, or 34 blow black smoke when hammering (i know i own one) the rb26 motor u could say is similar to a rotary engine by that i mean they love to rev the more it revs the more it burns oil thus u get the black smoke out the back, it's normal u just gotta check the oil and change it regularly.:D
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-82129
Whytry,
Well I'd have to disagree with you on this. I have owned
a 97 33 GTR-V for 2 1/2 years and currently drive a 92 32
GTR and in all the time I have owned them neither blew
copious amounts of black smoke under load and by that
I mean dancing on the red line. especially the 33.
Neither were heavily modified thou! and when you
start playing with the computers etc they tend to
run pretty rich to protect the engine this adds to the
black smoke "stealth" effect :D
ohh and if your oil is cold any car will blow weed! but
I do know that the silver 32 in phillip is a heavy smoker
all the time!!!
R,
Adrian
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-82138
nope mine is red with gold rims just got it back on road after 6 months in workshop getting 'mods' has at moment QLD rego but i'm changing it to N.S.W. rego soon after i 'run' in motor, it's an r32 gtr.
was out and about tuesday night and last night, around civic, woden and manuka.
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83067
nah that gunmetal one is mine, i only drive it to uni,so thats why its always on william slim. Hey Goran how you goin im the guy that rang bout the power FC. You car is so sweat i wnat you to take me for a drive when jake has it all finished off. He is doin some stuff on mine after some disapointing dyno results that were no were near where they should be we should catch up some time!!
Daniel
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83373
hey daniel
yeah for sure i'll take you for a spin, i'm just waiting for the hand controller to come in.
yeah jake was telling me he too was dissapointed in the results, but that ok till you get it sorted out properly and hell when u do man that thing WILL absolutely haul some serious butt.
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83452
Guest thedriver
neergnevets -
Well I got into a R32 GTR and let me tell you.. they are small and tight.... obviously designed for Japanese in mind...a lot smaller than my Mx6.
The R33 is a lot bigger and roomier inside. Even the more open dash plan makes it feel larger. This seems like it was taking into account they may be exported to the rest of the world.
So it's back to the R33 for me... will have to save some more!
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-87275
I sold my MX-6 yesterday! I had to drive it to the buyers
house, so I went straight form the GTR (32) to the Mazda.
I honestly didn't think that their was that much difference? I guess if you've got a sunroof in the MX-6 open you could stick
ya head out!!! :)
Is anyone interested in a track day?
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-87315
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
