I checked the usual things for headgasket like color of coolant/oil and if the oil filler cap has that milkshake stuff but everything looks good
ah ok I was about to record a video but the battery is completely empty. I'll charge it up later and upload the vid. Hopefully its just the coils since i planned to get splitfires anyway
It sounds like a misfire. RB's go surprisingly good on 5cyl. The easiest way is to have your car idling, and unplug a coilpack or an injector and see/find which one doesn't make the sound change. That's your problem cylinder. The consult cable means you don't have to actually unplug stuff, can turn it off electronically.
this is the tps on throttle body, the grey plug is not connected, what is the grey plug for? the wires from this do they need to be connected? also car is standard no boost controllers 👍
I dont have a consult setup. Is there another way to do this?
