It sounds like a misfire. RB's go surprisingly good on 5cyl. The easiest way is to have your car idling, and unplug a coilpack or an injector and see/find which one doesn't make the sound change. That's your problem cylinder. The consult cable means you don't have to actually unplug stuff, can turn it off electronically.
this is the tps on throttle body, the grey plug is not connected, what is the grey plug for? the wires from this do they need to be connected? also car is standard no boost controllers 👍
I dont have a consult setup. Is there another way to do this?
it got a little bit over the middle of the temp gauge on the track but not really overheating.
The tyre fitment will be important here. You may be able to fit a super wide low offset wheel in but then you will be limited to stretch tyres.. I personally run a 18x9.5 +11 (rear) and 18x9 +18 (front) on my R33 and the tyres are only slightly stretched (check my build for pics). However, mine is definitely on the more snug fitting side.. IMO a 9.5" rim size (all round) id say a +20 to +25 on the rear and +25 to +30 on the front would be a reasonable fit with some room for decent tyres..
