Skylines Australia NSW Wakefield Park Trackday 1/11/04
ahh ok....pads 50% is about what you would use in a really hard day. but either way, take a spare set of pads.
I can assure you from experience:
1) you cant buy skyline pads in goulburn. anywhere.
2) its a long drive home with metal on metal if you run out of pads
  • Replies 104
Did you guys need a full jump suit (i.e racing suit) and extinguisher mounted in the car for this event (that is now about 2 weeks ago. :rant:
Do many of them require a racing suit etc?
Thanks
hello tiger :)
and pretty blue dancing shoes too :rant:
The only time I've needed a suit outside a full race meeting was an ARDC practice day but even then it was for unregistered cars only.
CAMS often require extinguisher, not a bad idea to carry one anyway.....try a search for "skylinegeoff +3 foot flame"
