Just a quick question..
I normally run Motul 10w/30w in my rb20det .. as my cars done 120,000 ive decided to run a 10w rather then a 5w due for a little bit more added protection.
However today i stopped into super cheap to get some 'cheap oil' to flush out my engine and the guy rekons i have to run 15w/40w due to 10w/30w is too light for australian conditions
so which is the correct answer?
https://www.sau.com.au/forums/topic/52741-oils-10w-or-15w/
The higher the W (winter) rating doesnt mean better protection. The lower the number, the better cold start fluidity which is actually good :cheers: Ie 0W40 provide better cold protection than an equivalent 15W40.
I'd probably get a 10W/40 (or any 0/5/10W 40) for your car considering its done a few miles and also our summers are damn hot, and moreover because I would assume your car is modified! Something like Shell Helix Ultra 5W40 or Motul Turbolight 10W40.
https://www.sau.com.au/forums/topic/52741-oils-10w-or-15w/#findComment-1037394
Yeah i run turbo light, I may have another look to see if theres a 10w/40 in the motul range.
I was under the impression the 10w was the weight the oil is when the egine is cold,and the 30 is the weight when the engine is hot, there for the highter the number the thicker the oil the thicker the engine protection
the lower the number the thinner the oil the lesser the engine protection however its lighter which is better performance
does that sound correct?
And for the record, im currently not modified :cheers:
https://www.sau.com.au/forums/topic/52741-oils-10w-or-15w/#findComment-1037435
Yup your understanding is half correct. You want oil to be as thin as possible when cold so it circulates quickly to areas where oil is needed. An oil at 20C is on average 10x thicker than it is at 100C. So an oil doesnt 'thicken up' as the temp rises. Its just a number which is relative to the viscosity of a 'straight weight oil' compared to a multiweight like a 10W40. More info here;
http://www.vtr.org/maintain/oil-overview.html
You do a get a minute increase in performance using a 30 instead of a 40 weight oil. BUt its in the order of 0.5 - 1% which is almost nil. I'd stick with a 40 weight. 50 is abit too thick and in some cases, cause more wear in very cold climates.
https://www.sau.com.au/forums/topic/52741-oils-10w-or-15w/#findComment-1037884
0W has always seemed too light for my liking.. and given things really don't get that cold here I'd stick with at least a 5W. Oil pressure is important too, not just flow. The other rating is the hot viscosity which is more important (since, if you boost your car when it's cold you're an idiot). 40 for city use and 60 for track use is what I go by... I use motul 8100 which is 5W-40.
https://www.sau.com.au/forums/topic/52741-oils-10w-or-15w/#findComment-1040386
I run 10/30 i dont want to run less then 10 due to my engine being a bit old.
however ive been told 30 is too light or soemthing.
im just so confused. all i know is i live in QLD atm with sumemr coming up it gets supidly hot up here and i want the best oil to protect my engine.
I use motul oil and want to stick with it. but i dont think they make a 10/40
https://www.sau.com.au/forums/topic/52741-oils-10w-or-15w/#findComment-1040986
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
    • yeah the south island is stunning, the wifes family is from the west coast down there so we were down there for christmas.   a high 10 would be a stretch but hilarious if it happened. fourth gear is its party gear, i don't have traction to throw more at it at lower speeds. I've found passengers don't think its that fast, i think it's because it has a digital dash so they can't see the needle move so they have no sense of speed
    • You have (externally anyway) a lot of patience!  At the very least your patience has rewarded you financially even if you decided you were over it!! I only just read your first experience of seeing the car, that would have been amazing!  Well documented too! It must be exciting knowing there's only 10 months left until you can get it on a boat and on it's way!!!???
