well i've had a couple coilpacks die recently and a couple people telling me the setup on the rb motors are prone to failure due to copping all the heat from the engine and dont generate a very strong spark. so i've started considering alternative spark setups.
has anyone had much experiance in using different coilpack setups with the standard ECU? such as using external camira/bosch coils and leads and setting it up as a wasted spark system?
https://www.sau.com.au/forums/topic/52754-alternatives-to-standard-coilpacks/
I agree with Joel, our R32 GTST has 170,000 k's on the original coil packs, the GTR has 142,000 on the original coil packs, the Stagea has 102,000k's on the original coil packs. The old R32 GTR still had its original coil packs and it is close to 200,000 k's now.
Personally, I haven't had a problem :(
My standard coils were working fine, but with higher horsepower applications then the SplitFires are the way to go:D Series II GTS-t coils are pretty crap though, as they have the modules inbuilt, and are much more prone to problems.
I left the the R34 GTT of the original list because it hasn't done that many k's. It has 265 rwkw and it's coils packs are std, maybe I am just lucky with them.
On the race cars we use a Motec CDI with Mercury outboard coils packs, because they are designed to work with CDI's multiple discharge.
To avoid coil pack failure I took the upper belt cover off and used a hole saw and file to make a tear drop shaped opening to the cam belt area. I then opened up the little ventilation fins in the rear section ( fins vent into the coil pack area / valley ) so I now have air flowing through from the outer most part of the fan, through the hole I made, between the cam pulleys, through the fins and down the valley taking some heat away from the coils then venting at the rear of the valley cover. ( Hope all that makes sense ).
Should work on any RB I would guess.
I've yet to finish the job off with a nice piece of mesh to stop any nasties getting in but it seems to have worked as I've never lost a coil pack in my R32.
As Ed said my ones died ~80,000Ks back when it was N/A and only proved annoying at idle, when the turbo went on at 110,000K's it was all too noticable....the current R33 ones I'm using seem to be OK though (fingers crossed)
I did actually consider setting the packs up in a corner of the engine bay with spark leads going to the cylinders.
From what I've heard, the splitfires are the go.
There was an R31 with a worked RB20 I saw after the Drift Nationals with 6 older style cylindrical ones on a plate on the firewall with leads to the plugs. Not sure about the electronics behind the set up unfortunately..
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
