Well, its on again, SAU's second annual Observation Cruise.
For those of you that came along last time, I'm sure you have got over the arguments with your navigator by now. For new attendees, you've got an interesting day ahead :cheers:
What the hell is it?
Basically its a cruise along some top raods to a mystery location, with a BBQ at the destination.
How will we find it?
We'll give you clues to find the destination. And this year I can tell the difference between left and right ;)
You'll need more than one person per car, so they can look while you drive sedately and at the speed limit.
What will we get?
Well, a great BBQ lunch and day out for one.
Who can come along?
The entrant will need to be a member of the club, (one per car), but anyone else is welcome to join in
What will it cost us?
Entry fee is $15 per car. This includes lunch for everyone in the car.
When and Where is it?
Date: Sunday 17th October
Time: 9.45am for 10am Start.
Starting: Kirawee, exact location TBA
Finishing: C'mon, I'm not giving it away that easily
The entry form and supp regs will be posted in the next few days :)
For those of you who are scard of finding Kirawee on your own, there will be a meet up at Carpark 6c in Homebush, 8.30 for a 9am departure. The first cars will be leaving Kirawee at 10am sharp
For club members, the secret, members thread is here: http://www.skylinesaustralia.com/forums/sh...512#post1037512
Who is coming along this year?
Theres about 20 people coming along so far, anyone else interested?
Non club members are welcome as long as one person per car is a member....if not you can join on the day.
Looks like damn good weather for a drive in the country and a BBQ :D
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
