  • Replies 45
Sad to see that these things happen. Condolences to all concerned.
My 2cents worth:
I think there should be some sort of compulsory defensive diriving course to all new drivers and repeat traffic infringement offenders.
To say that there's no money for it is debatable - where does all the speed camera and red-light camera revenue go? Surely, the government is making a killing on the takings here, and they could at least put part of it back into the system in the way of (proper) driving lessons, better roads, etc.
Anyone who has picked up/received the last few months (or maybe a year or so's worth) copies of WHEELS magazine can read for themselves the few basic measures that could be taken to reduce the stats on road deaths and injuries... Here's just a few, taken from the October '04 issue:
* Better focus on roadcraft - driving is a skill, whereas current licensing procedures focus on rule compliance. Anyone can follow the rules and still be killed or injured in a car accident
* Raise the licensing standard - how many people (us enthusiasts included) would know how to control an unexpected slide, or steer and/or brake to avoid an accident? How many people know how to use their mirrors properly? How often do you witness some clown who doesn't know the best/safest procedure on entering a freeway and merging with traffic? How many people know what do and how to react in an emergency stop? How many people panic when the ABS kicks in and the pedal starts pulsing beneath their feet?
* Tackle over-confidence and risk-taking - we've all been there, so no need to explain this one!
There are plenty of initiatives that have been shown over the past year or so which would probably cost the govt and the community less than a 10th of what it costs when someone (just one person, mind you) is injured or loses their life in a tragedy.
Now, morbid as it may sound, I believe that when your number's up, there's probably nothing you can do about it. But isn't it annoying when you have a near-miss or accident (whether it was your fault or someone else's) and you get the shakes because you know that with better roadcraft skills that situation you just got out of (or just got into) could have been avoided?
Education, not legislation!
/end rant
Nick T.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
