Hiya, I have been researching tyres for the months while waiting for my import to arrive... the day has finally come and it will get some new rubber and a compliance badge this week (yay!) so I have got down to two tyre choices...
Bridgestone S03 or Falken 451.
In WA tyre costs stupid amounts, and the 451s in 235/45/17 and 255/40/17 are about $1400 which is about the same as the S03's, so cost is not a real deciding factor.
Whats the pick?
I like the 451's for looks, curb guard (I dont think the S03 has one) to protect my new mags, and seem to get good reviews, and supposed good tread life and wet weather grip, quiet.
The S03's sound like a technically superior tyre, but I hear they need regular rotation to avoid tramlining (a problem with differing tyre sizes front to rear) and have short tread life, although are awesome in the wet.
I have also had a few people tell me they let go pretty abrubtly whereas the 451 gives you plenty of warning.
Anyone got any comments on any of this? Without trying them myself its hard to find out which is a better tyre, but I would like to try and make the right decision :D
Conrad
https://www.sau.com.au/forums/topic/5277-tyre-choices-down-to-451-vs-s03/
I had SO-2's on my GTR and they were awesome. Now i need new tyres and looking at SO-3's. The tyre guy tells me they are better than SO-2's but i too want to know if anyone else has had experiences.
And they cost $500.00 each
My tyre sizes are 265/35/18 all round.
Cheers
Im all for saving money, but to save money on Tyres and brakes is the worst thing you can do in a car. I hope you have never been or will be in a comprising situation with your car and another where the difference between good tyres and bloody good tyres is your damage.
I think everyone has had shite tyres on their cars at one time or another, but i have been in a situation where my tyres let me down and if i had a good set on then i would have been ok.
Cheers
I believe that it is not the saving of money which is the issue but your choice of tyres and brakes which is important, if you can get the same quality for cheaper then hey ... Im all for saving money ...and all for having good brakes and tyres...
I have been running a set of Falken Azenis tyres (they are a semi slick bottom range race tyre...too crap to race but too soft for the road type of thing) 225-50-16's for $190 ea.
They have lasted about 10,000kms... not bad really. They are about as grippy as a normal tyre when cold, if you really go for a blast and get them warmed up they perform quite well. One of the main benefits is the stiffer sidewall, very predictable etc.
Cheers
Russ
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
