Hiya, what is the recommended wheel alignment settings for a R33 GTS-T?
Will be getting the car tweaked up for registration this week, and looking to get a good alignment on it for street work.
Had my girlfriends FTO set up without providing any setitngs and they gave it 0 degrees toe front and rear, and wanders all over the road now :D
Thanks
Conrad
You should post the settings (that whiteline suggest) so that everyone that is interested can see them too!(only trying to be helpful for the people of the fourm)
T=touring S=sport (types of whiteline kits)
for R32 GTR:
.………..Camber…….Caster……....Toe…..
.…………..Deg ……….Deg…….....mm/side.
Front T.…-2.0……L2.5 / R2.0….…0.0….
..……. S.…-2.5……L2.5 / R2.0….…0.0….
.Rear T.…-1.0……….n/a………...0.5mm in
……....S.…-1.0……….n/a………...0.5mm in
R32 GTS-t:
.………..Camber…….Caster…..….Toe…..
.…………..Deg ……….Deg……....mm/side.
Front T.…-1.5……L6.0 / R5.5……0.0….
..……. S.…-2.0……L6.0 / R5.5……0.0….
.Rear T.…-1.25……..n/a……….0.5mm in
……....S.…-1.25……..n/a……….0.5mm in
R33 GTS-t:
.………..Camber…….Caster……...Toe…..
Front T.…-1.5……L7.0 / R6.5……0.0….
……....S.…-2.0……L7.0 / R6.5……0.0….
.Rear T.…-1.0………..n/a………...1mm in
……....S.…-1.5....…….n/a………0.5mm in
R33 GTR:
…………....Deg ……….Deg……....mm/side.
Front T.…-1.5……L5.5 / R5.0…..…0.0….
……....S.…-2.0……L5.5 / R5.0…..…0.0….
….....S.…-1.0……….n/a………...0.5mm in
Please note that these settings are only the ones that whiteline suggest for their lowered cars!(though I used the same specs for my car and works great!!)
MEGA
P.s Inside tyre wear will be a little problem for those who use 2 or more degrees of camber!(from previous experience with my car.)
I would suggest that more caster than they reccomend would be beneficial...also a little toe out on the front would be beneficial.
I run:
for and r32 gtst
Front : -2.5 camber 1mm toe out +7-8 caster
Rear : -1.4 camber 0 toe
I have removed the hicas rack from the rear and I find that with the front set up as above it has more than enough grip to have the rear toe pretty straight....with the stock gtst setup I found the rear had great grip and would push the front into understeer very easily...had to run toe out on the rear to get the front to turn in.
You really have to experiment a bit...make sure you keep a record of what you r settings are and note the differences in handling...then next time you get an alignment you will have a better idea of what might suit your car and driving style.
Cheers,
Russ
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
