Hey guys, yeah i get popping noises from my exhaust when i hit the high revs and in turn stops pulling at that point. i was told it was my car pinging. Wat u think is d problem? at the moment my car has a hks t2835 turbo, 3 inch full exhaust sytem.remaped chip...and pod filter...das all... i hvae my high boost set on 14psi...but it still pops on low boost which hits 10 psi....please help
hmmm i'd heard that the popping was cause skylines run rich and sometimes don't burn all the fuel. But not sure in your case. I'm no expert on this stuff...could it be detonating then the comp retards the timing or something??
Sorry not very helpful i know
Could be a number of things,
Spark Plugs - Gap them to .7
Coil Packs - Need to tape them up with electrical tape because the spark is arking out the side.
As shif_tea said it could be a fuel problem and dumping too much fuel in - SAFC II will fix this.
AirFlow Meter, A Faulty wire or dirty connection can cause a missfire/hesitation's
The list goes on.
Take it to a mechanic and get them too look at it, But if you want to try and fix it your self start with the spark plugs & coil packs.
:P
Jun
You do have at least a 500hp fuel pump?? how high a revs are we talking 7500, 8200 ?? or else take it back to the mech who put the chip in and tell him that the car is farked and he must fix it or you will get very angry at him and not be his friend anymorw.. works for me..
This could be the problem, my mates r32 was running so rich, he had this similar problem, they re-tuned & shaved it down a tad, & the problem dissipated!
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
