Yes exactly, looks like NismoR34 is gonna own himself again like he did in the MAS thread :D
:runs and hides:
INSANE you are the one who "owned" yourself this morning...it was approximately 0832 hours, had just been raining and what do I hear screaming down the Monash Freeway just after warrigal rd entrance, ducking in and out of lanes like a bat out of hell :burnout:??? None other than the keyboard-t88-on-board-warrior himself :rofl: this one will be good for publicity :D Just as well you changed yr number plates from yr user id :rofl:
Hrmm....
Didn't Ash come raging through the forums at 3am this morning like the new sherrif in town and close this thread? :( Looks like someone re-opened it!
So I was coming back from a security breakfast/briefing at Crown this morning down clarendon st doing 60, wet roads, etc. this friggin taxi driver pulls out in right front of me, he wasnt even looking for oncoming traffic. I am thankful for my ABS and brembo's.. Then the cheeky shit just waves at me as if to say "no worries thanks for letting me in" stupid fux0r.. :uzi: Just shows you can be as confident as you are in your own driving ability, but you also need to be aware of other drivers and be prepared for unexpected events.
Hrmm....
Didn't Ash come raging through the forums at 3am this morning like the new sherrif in town and close this thread? :)  Looks like someone re-opened it!
:werd:
Taxi drivers have to be right up there up the worst drivers on the roads. Some of the stunts they pull that i've seen just freak me out :(
INSANE you are the one who "owned" yourself this morning...it was approximately 0832 hours, had just been raining and what do I hear screaming down the Monash Freeway just after warrigal rd entrance, ducking in and out of lanes like a bat out of hell :burnout:??? None other than the keyboard-t88-on-board-warrior himself :( this one will be good for publicity :) Just as well you changed yr number plates from yr user id :D
wrong thread man, you already posted this in the other one!!!! :alcoholic
Hrmm....
no, i cant close Vic General stuff. (yet).. Narkie has to do that.
Ive only got mod access to the Vic Events/Forced Induction
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
