Hi Everyone,
I have owned my R32 GTST for a couple of years now and have decided its time for a upgrade. I have seen around the place people talking about the conversion to a RB30det and this has sparked my interest.
I am unsure where to start this project and how much its going to cost me if I am looking at producing up to 300rwkw, will I need forgies and rods, what about the gear box and transmission will they hold up under that kind of power?
If anyone can point me in the right direction to start this project that would be great.
https://www.sau.com.au/forums/topic/52818-where-to-start-rb30det-project/
Picking your self up a R32 RB25DE and dropping a set of forgy's in it is a easy swap.
You don't have to worry about the extra 38-40mm deck height that fouls the bonnet.
BUT.. if you are after a really tough street car then the rb30det can't be beaten.
Thats if you are willing to put up with the few extra hassles getting it in there.
Its an expensive change over as you can't simply drop the 30det in and expect it to run.
You will also need an ECU and it will have to be tuned.
For a simple buildup with forged pistons, a rebuilt head and mild port/polish expect close to $6000.
Then you will need all the little extra's that add up very quickly - Heater/radiator/plenum water hoses ~$400, thermostat ~$50, fan belts ~$50... the list goes on.. :P
With turbo, injectors, ecu etc expect to spend around $10,000-$12,000
I have had engine building experience from my kingswood days, is this type of project something that I could take on and do myself or are the tolerances to tight that it would be better of performed by a qualified tuning shop, maybe someone could recommend one here in Melbourne that has experience in these engines before?
If you have built engines before you would have used a plastiguage.. maybe it was called something else.
In short you basically you shove it in between the two bearing surfaces and torque it up.
You then read what the clearance is.. If it is within spec you are fine if it isn't you need different bearings to bring the clearance within spec.
    • Went to a drift practice day at a local circuit (held on the reserve parking area behind the grandstand) for the first time in about 15 years. Some kei cars were drifting as well, a not so surprising Suzuki Carry truck, and two 1st gen Daihatsu Copens that were converted to rear wheel drive(!) using Daihatsu Boon X4 transfer case, prop shaft and rear diff, obviously omitting the front driveshafts. They looked really fun to slide. I heard that they cost "about half" as much as a Nissan Silvia etc to run.  On the track 'Tech M' a local BMW tuning garage had a customer track day. Mainly recent models but there was one E36 which looked ancient among all the current models. It was cool watching the drifting and then turning around and seeing random people thrashing their M3/4s  central-circuit-drift-practice-2025-05-18-long-yt.mp4
    • I prefer it with those wheels (sacrilege?) 馃構 Here's a photo of a fully original one for reference. The price is $350K....
    • I would like to keep it around 15k but if I need more to make it reliable and not have to worry about the car breaking I can go more. It's my project car so I'm just trying g to figure out what needs to be in it i know basic things like turbo cams injectors I'm just unsure of the size and the specifics so I'm spending alot of time on Google and its mostly rb25 and rb26 not alot on neo
    • This. They would need some tricky maneouvering to keep the income out of the country (the US). Which isn't helpful if that's where you want the income to end up.
