  • Replies 48
Actually, much to the dissapointment of my fans, I tend to agree with a lot of what OVL says, even if I dont agree with the constant typos, lack of any sort of grammatical structure and his insistance on using alternating CAPS WORDS AND then lower CASE WITHOUT any reasoning.
But I'm still gonna post a picture:
Anyway, back to the topic of this thread...
I'd be up for being in the SAU section for this 'Takeover' as long as Mr Plod doesn't decide to turn it into a major defect fest. (QSC and BoostCruising are heavily monitored by police, who might see this as an opportunity to screw many people over in the same place at the same time)
OVL basically started bwcp by having meetings the local council and cunstables about letting car enthusiasts use that carpark. Good idea cause it kept everyone off the spit / esplanade / etc.
Its just ruined because of all the car ****s who turn up. Car ****s attract weiners in shitboxes. Weiners in shitboxes attract burnouts. Burnouts attract cops.
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
