Hey slacker how you been??
Remeber you statement below before you replt to my post :)
HOWEVER!!!! Please remember that this is for my own amusement and that essentially I don't really give a stuff about you or your problems be they real or fabricated.
Dave informs me that you mum is a MILF and sister is SILF and dad is a DILF (i am not into that tho, wonder what he was thinking), is it wrong for me to want to be the salami in the sandwich between your MILF and SILF??? :(
I see that you, like most people who've attempted to engage my interest on the topic of my thread, are bereft of the skills required to comprehend my posts.
Most didn't understand my point during my inital entry.
You, it seems, missed the intent of my last.
If you had posted your above question earlier this morning or in fact sometime last night I would be in a position to pass judgement on you.
However you'll see by my last post that I"VE PULLED THE PLUG!!!!!
Thats right, I'm no longer passing judgement on anyone. However spewing forth abuse isn't boring me yet so I'll happily give you a bit of that.
But to answer your question, I've been good Bro, hope you are travelling nicely :headbang:
