Well again... the soarer has been defected...
-Tyres not complying with load ratings (it has the ceffy wheels on it until i get the tyres on the soarer wheels replaced as i got a puncture)
-Ground clearance (car has stock suspension but apparently the exhaust comes down too low)
-Exhaust (Too loud... had a chat with him tho about it and apparently i wont get an EPA notice cause its been tested before and they only test the soarers at 3200rpm unlike most other cars)
no fine... again... so thats cool.
i think this is the first major its had... but the 3rd canary
selling it anyway so i have to get a RWC regardless...
anyone want a loud defectable soarer? :P
funny thing was this guy had pulled me over before on nepean hwy because the front number plate was mounted to the left... he said he remembered and was glad to see i at least got that fixed up rofl
https://www.sau.com.au/forums/topic/52849-another-defect-lol/
heh, just got pulled up then on kellets road in rowville, breath test, license check, and car check
'wheres the blow of valve'
me 'its pretty standard, standard blow of valves that aren't venting to atmosphere'
him 'trying to find tyre load rating placard in english on this thing'
another cop 'looks pretty low'
i just kept srugging saying i think its pretty standard (which it is kinda)...
he got the wheely thing out rolled it under my car, hits my mufler way to easy,
cops like no your about 20-25mm to low,
me 'really? i got it raised a month ago about 2 cm if not more since when i bought it, it was to low'
cop 'they raise it to legal height?'
me 'umm i guess not....'
they let me off - i have a pretty clean driving history maybe that helped... was nice to them and car is pretty standard, im thankful for that
my historys clean as well... minus one small fine about 2 years ago and the soarers std minus the exhaust, wheels and kit.
like what ash said... the dumb thing is (I HOPE UR READING THIS U TARDS) that the cops think they are puting us out and that fixing all this hassles us and that sooner or later we will stop modifying our far more l337 than their shitbox cars... WRONG! it takes all of one saturday and a few beers.... gives us something to do :rofl:
THANKS GUYS!
I was just waiting for something to happen driving my line last night. Especially after recent events.
Fortunately only saw one cop car, patroling local shopping centre carpark. They doubled back as i walked in to safeways, were gone when i returned.
Only pulled over once for 'random' stop this year.
Honestly i didn't notice what cars they were, there was more than 1, maybe 2-3? and they didn't pull me over directly, they had a couple of cars pulled over already, like at a booze bus, but there was no booz bus... were just normal cop cars as far as i can remember...
so sorry no heads up on what to look out for :rolleyes: it was about 9:30pm on wed night...
    • Also did some work to the shed and a massive clean out of stuff. It's now got a small fab/dirty room and has helped keep shed cleaner. Built some new work benches and re organised things also got a TV out there so good having something playing while working on the cars. Got a pedestal drill and linisher off a mate that need to pick up too.
    • First thought, have your current injectors flow tested. If they test fine, keep the diagnostics going. It's not the injectors. If the injectors are the issue, find some new or used (cleaned and flow tested) injectors.  While I really love a good excuse to get a modern ECU installed, just needing new injectors probably isn't a good enough reason to do so.
    • A bit from column A, B and C. Mainly C   Update time, after deciding it was time to tick off a bucket list goal I finished up full time at MSR and have gotten back behind the wheel and making progress on the S15. Goal has been to drive Bathurst at an event and I have had my entry accepted for Challenge Bathurst in November. Since I don't want to go unprepared I need it running to test and get comfortable.  Been chipping away at it and started by stripping inside, getting it all cleaned and sealing some holes up. With stripping inside I removed the whole wiring loom and found a few surprises.......... its pretty butchered and shit branching and I'm not a fan of the haltech fuse boxes so it's all out and trying to come up with a plan to rewire it all either new fuse/relay box or pdm.  I haven't been happy with how I did the intercooler mounting and been wanting to tuck it up under rad support. O e issue with that is headlights will need a decent trim or get replacement covers. Took the time to mount it with some stand off's and new hardware. Stands are some m8 button bolts, washer, aluminium tube and factory radiator top mount rubbers. It's nice and solid also stiffens rad support which still requires some trimming. Bonus of factory rad mounting is used all factory hoses just need to weld a pressure cap to radiator now. Got sensor block and fuel filter mounted. Plan today is to get vac lines all sorted with push in nylon tube and design oil cooler mounting solution.  Been driving BRZ a heap and went out to Morgan Park for time attack and went pretty well for a wet day. https://youtu.be/gAlQgcQpWj4?si=kojOAOjhhX_X3AXR Getting pretty comfortable in it now and want to do a few more bits to it but restraining myself as don't need 2 race cars at the moment.
    • @sunsetR33 There is obviously a huge culture gap here. There is nothing in place like this in Australia, where if you fit a Mines branded pipe and later replace it with a Jun branded pipe, both pipes are essentially identical - BAM - huge penalties! Where is the Mines pipe?? You can't have a Jun pipe when you said you had a Mines pipe!  Makes no sense to me. Surely makes no sense to anyone else here either.  I'm sure a lot of us would agree that our registration/engineering system is pretty stupid at times, but it's not that stupid.  *** More serious question here. If you replace a factory rubber hose with a silicone hose, is the car illegally on the road now? Does it become legal if you have certification of what brand the silicone hose is? Then would it become illegal again if you replaced that silicone hose with a difference brand of silicone hose? And then would it become legal again if you had certification of the new brand of silicone hose?  I really want to know that answer to that question.
    • Good you making progress with this rig. Aluminium welding is painful to learn, have you got a pedal as I found it so much easier with one. If that's the AMG I think it is, you would working with Benny?
