Hey dude,
I have been looking into this unit myself and it seems to be a very decent piece of kit, at a very attractive price point too!
They have released plug-in versions for popular cars such as 'S' series nissans, R33's, WRX's etc. These are a full replacement ECU that can be tuned by a optional hand controller or laptop with appropriate software. The good thing about having the hand controller is that it can display all sorts of info about the car.
Check out www.wolfems.com.au for more.
Mat
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-81159
Originally posted by GOT BOOST
i had wolfs on 3 of my rotary cars 2d 3d V2 & V3 and helped my friends with his new 3d version 4. i dont like the version 4 and speaking to a few people they are not overly impressed either. formaz sold wolf now they are pushing Haltech.
An explaination of why you dont like it (version 4, not 3.) would be appreciated. :D
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-81290
Nothing against Formaz Got Boost, but their name since changing ownership has not been the best.
I would be interested in seeing why they do not like the V4...more tuning resolution, faster processor etc, surely that would make it a better product. Maybe they don't like the laptop interface???
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-81496
Mat
I am definitely going for the Wolf V4 plug & play for the R32 GTR.
As you know, I got to know the PFC very well on my old S15. The unit has some great pros, however one of the biggest cons was that there is no temperature correction.
Detonation was much more evident during the summer months and during the day. As you only have the choice of only one set of "custom" maps or the factory (default) maps, this means that you either run a conservative map in the cold weather, or have to spend a fair bit of time remapping for summer/daytime performance runs.
The PFC also uses MAF (airflowmeter) rather than MAP. This is not really a problem in terms of flow restrictions as you can bolt on a big Z32 meter (or a pair of the suckers for an RB26). Don't know which option I will use for the GTR as I have heard that the 6 throttle bodies don't give a stable MAP reading.
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-82271
Yep - he knows his Wolf systems pretty well and is bloody patient when it comes to ironing out "gremlins" when tuning.
Guess I'm biased towards Grant/Steve after the huge effort that they put in on the S15 and they didn't even supply the ECU.
There should be a few Version 4 installations running around now and I will be speaking to some of the guys that have gone this route.
BTW - Jash has landed that blue V-Spec. Drop by there and give me a first hand report if you are ever in the area.....
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-82990
Originally posted by Gav
Mat
PFC does have temp correction (Lamda) BTW.
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-83696
I'm not sure what you're referring to.
PFC generally uses only the existing sensors. On the SR20 motors there is no measure of air intake temp, therefore the PFC cannot correct for this. I don't think the RB motors have this either.
Lamda refers to the stoichiometric air/fuel ratio of 14.7 and is not directly related to temp correction. The PFC does use the O2 meter for closed loop (cruise) mode.
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-83798
Sorry gav I meant temp compensation lamda as in this comparison:
http://www.users.bigpond.net.au/r33/ecu.jpg
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-83941
